[Qgis-user] Delimited Text Plug-in claiming text file not valid
custard custard at westnet.com.au
Mon Feb 14 17:46:09 PST 2011
I like the revamp of the Delimited Text Plugin in trunk - it feels much easier to use.
However...
While opening a file today I noticed that I didn't get an oppertunity to define a CRS for the file - which I used to in 1.6.
Before reporting that I thought I'd update trunk (which is now revision 15172) and am getting a completly different error from the same file. It says:
The layer M:/Data/WesternAustralia/SH51-09/Anthill/MMAnthill/Exports/20110215MKOAHCollars.csv?delimiter=%5B,%5D&delimiterType=regexp&xField=East_LG&yField=North_LG is not a valid layer and can not be added to the map
I've reinstalled trunk (which reinstalled the plugin) to no effect. Does anyone have any other suggestions.
I can open this file in 1.6 with little or no problems.
Also, in the first situation, if a file is opened in the wrong CRS, is there a way to redefine the CRS - withouth having the points converted?
(I'm guessing I could edit the .prj file - would that be right?)
Thanks,
Ramon.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110215/9de18095/attachment.html>
