[Qgis-user] use several tables in one dynamic form
Andreas Neumann
a.neumann at carto.net
Tue Feb 15 07:41:36 PST 2011
you'd have to use python and pyqt, currently. You can have additional
form elements in your .ui file that do not match column names. You can
have an initialize python function on the form and additional python
logic to deal with related tables.
There will be improvements later this year. The table join branch was
just recently merged and there will be more form improvements later on.
If you need a solution now, you'd have to use python and pyqt4.
Andreas
On Tue, 15 Feb 2011 13:50:22 +0100, wrote:
> Hi,
> Since 1.4, QGIS can use .ui file created with Qt Designer to make
> dynamic forms for entering new attribute data. The way it works with
> widget name seems to limit it to the current table, is there any way
> to aggregate fields from several tables of a sqlite file into one
> form
> I would like to provide a usb/networkless package for a research
> program with qgis as the sole frontend (an extjs form+actions would
> take the user out of qgis) . If not possible, what would be the best
> method to do so without triggering many dependencies ?
> Regards,
> MORREALE Jean Roc
> Qgis-user mailing list
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
