[Qgis-user] qgis/osgeo4w error after update
Alister Hood
alister.hood at synergine.com
Wed Feb 16 13:59:13 PST 2011
Hi again,
> -----Original Message-----
> From: Alister Hood
> Sent: Thursday, 17 February 2011 10:50 a.m.
> To: 'qgis-user at lists.osgeo.org'
> Subject: Re: [Qgis-user] qgis/osgeo4w error after update
> Hi everybody,
> > Date: Wed, 16 Feb 2011 12:53:35 +0000
> > From: Giovanni Manghi <giovanni.manghi at gmail.com>
> > Subject: [Qgis-user] qgis/osgeo4w error after update
> > To: qgis-user at lists.osgeo.org
> > Message-ID: <1297860815.1991.5.camel at sibirica>
> > Content-Type: text/plain; charset="UTF-8"
> > I updated my osgeo4w installation and after that I get this
> > "qgis.exe - Entry Point Not Found" and "The procedure entry
> > point ?driver at QSqlDatabase@@SA?AVQStringList@@XZ could not be
located
> > in
> > the dynamic link library QtSql4.dll"
> > while trying to run both qgis 1.6 and trunk.
> > Anyone else has this problem?
> > Reinstalling from scratch gives the same problem.
> > Cheers
> > -- Giovanni --
> I was also getting this error with the latest build, but running the
> installer again I found that it hadn't installed the latest version of
> all the QT related packages. Installing these solved the problem.
> I was also wondering why the latest build refuses to install without
> GRASS...
> Regards,
> Alister
Sorry, I guess I shouldn't say it "refuses to install without GRASS",
but
it insists that GRASS is required for it to function properly. Is this
true? I haven't had any problems without GRASS so far.
Alister
