[Qgis-user] SIP problem on startup
John
washakie at gmail.com
Thu Feb 17 03:19:10 PST 2011
Sorry, but do you know what sources those would be? I already removed
the ppa for unstablegis and added a qgis.list in my
/etc/apt/sources.list.d/ directory for the trunk. But I guess you
refer to something such as directly from ubuntu? How can I do that?
--john
On Thu, Feb 17, 2011 at 11:27 AM, Noli Sicad <nsicad at gmail.com> wrote:
> John,
> Try to disable other qgis source aside from the trunk source, and see
> what are the packages available.
> Some of your installed packages needed python-qgis working are
> mismatched with the your install qgis (i.e qgis trunk) right now.
> Noli
> On 2/17/11, John <washakie at gmail.com> wrote:
>> Ah, okay... done. Now the SIP problem returns :/
>> Couldn't load PyQGIS.
>> Python support will be disabled.
>> Traceback (most recent call last):
>> File "", line 1, in
>> RuntimeError: the sip module implements API v8.0 but the qgis.core
>> module requires API v7.1
>> Python version:
>> 2.6.6 (r266:84292, Sep 15 2010, 16:41:53)
>> [GCC 4.4.5]
>> QGIS version:
>> 1.7.0-Trunk 'Trunk', 15175M
>> it seems I need to 'downgrade' my SIP module, or could a patch be
>> included in the nightly build to lessen the restriction? It seems a
>> check is being done to confirm that the SIP module is v7.1, is it
>> necessary that it can be set to be "at least" 7.1?
>> --john
>> On Thu, Feb 17, 2011 at 10:08 AM, Noli Sicad <nsicad at gmail.com> wrote:
>>> Hi John,
>>> You have to install python-qgis, then you will have "Fetch Python
>>> Plugin" in Plugin Menubar as first menu item.
>>> Noli
>>>> Thanks Noli,
>>>> Yes, Ubuntu 10.10
>>>> Trunk seems to be working for me, at least I don't get the error
>>>> message. Is there a way to test though?
>>>> Also, shouldn't I have a menu option: Plugins > Install Plugins? I
>>>> only have "Manage Plugins". How do I install new plugins?
>>>> Sorry for my ignorance,
>>>> john
>>>> On Thu, Feb 17, 2011 at 1:05 AM, Noli Sicad <nsicad at gmail.com> wrote:
>>>>> John,
>>>>> I guess this is in Linux i.e. Ubuntu.
>>>>> The sip module is new and not compatible with qgis.
>>>>> This is the same problem with this posting below.
>>>>> http://www.mail-archive.com/qgis-user@lists.osgeo.org/msg08737.html
>>>>> Noli
>>>>>> Apologies if this is a double post, but I had some problems with my
>>>>>> initial list subscription.
>>>>>> Hello, I'm trying to run QGIS, but I get the following error on start
>>>>>> up:
>>>>>> File "", line 1, in
>>>>>> Seems rather critical to have Python support.
>>>>>> Does anyone have any ideas?
>>>>>> Regards,
>>>>>> john
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Configuration
>>>> Plone 2.5.3-final,
>>>> CMF-1.6.4,
>>>> Zope (Zope 2.9.7-final, python 2.4.4, linux2),
>>>> Python 2.6
>>>> PIL 1.1.6
>>>> Mailman 2.1.9
>>>> Postfix 2.4.5
>>>> Procmail v3.22 2001/09/10
>>>> Basemap: 1.0
>>>> Matplotlib: 1.0.0
>> Configuration
>> Plone 2.5.3-final,
>> CMF-1.6.4,
>> Python 2.6
>> PIL 1.1.6
>> Mailman 2.1.9
>> Postfix 2.4.5
>> Basemap: 1.0
>> Matplotlib: 1.0.0
Configuration
Plone 2.5.3-final,
CMF-1.6.4,
Python 2.6
PIL 1.1.6
Mailman 2.1.9
Postfix 2.4.5
Basemap: 1.0
Matplotlib: 1.0.0
