[Qgis-user] SIP problem on startup
Noli Sicad nsicad at gmail.com
Thu Feb 17 02:27:28 PST 2011
John,
Try to disable other qgis source aside from the trunk source, and see
what are the packages available.
Some of your installed packages needed python-qgis working are
mismatched with the your install qgis (i.e qgis trunk) right now.
Noli
On 2/17/11, John <washakie at gmail.com> wrote:
> Ah, okay... done. Now the SIP problem returns :/
> Couldn't load PyQGIS.
> Python support will be disabled.
> Traceback (most recent call last):
>   File "", line 1, in
> RuntimeError: the sip module implements API v8.0 but the qgis.core
> module requires API v7.1
> Python version:
> 2.6.6 (r266:84292, Sep 15 2010, 16:41:53)
> [GCC 4.4.5]
> QGIS version:
> 1.7.0-Trunk 'Trunk', 15175M
> it seems I need to 'downgrade' my SIP module, or could a patch be
> included in the nightly build to lessen the restriction? It seems a
> check is being done to confirm that the SIP module is v7.1, is it
> necessary that it can be set to be "at least" 7.1?
> --john
> On Thu, Feb 17, 2011 at 10:08 AM, Noli Sicad <nsicad at gmail.com> wrote:
>> Hi John,
>> You have to install python-qgis, then you will have "Fetch Python
>> Plugin" in Plugin Menubar as first menu item.
>> Noli
>>> Thanks Noli,
>>> Yes, Ubuntu 10.10
>>> Trunk seems to be working for me, at least I don't get the error
>>> message. Is there a way to test though?
>>> Also, shouldn't I have a menu option: Plugins > Install Plugins? I
>>> only have "Manage Plugins". How do I install new plugins?
>>> Sorry for my ignorance,
>>> john
>>> On Thu, Feb 17, 2011 at 1:05 AM, Noli Sicad <nsicad at gmail.com> wrote:
>>>> John,
>>>> I guess this is in Linux i.e. Ubuntu.
>>>> The sip module is new and not compatible with qgis.
>>>> This is the same problem with this posting below.
>>>> http://www.mail-archive.com/qgis-user@lists.osgeo.org/msg08737.html
>>>> Noli
>>>>> Apologies if this is a double post, but I had some problems with my
>>>>> initial list subscription.
>>>>> Hello, I'm trying to run QGIS, but I get the following error on start
>>>>> up:
>>>>>  File "", line 1, in
>>>>> Seems rather critical to have Python support.
>>>>> Does anyone have any ideas?
>>>>> Regards,
>>>>> john
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Configuration
>>> Plone 2.5.3-final,
>>> CMF-1.6.4,
>>> Zope (Zope 2.9.7-final, python 2.4.4, linux2),
>>> Python 2.6
>>> PIL 1.1.6
>>> Mailman 2.1.9
>>> Postfix 2.4.5
>>> Procmail v3.22 2001/09/10
>>> Basemap: 1.0
>>> Matplotlib: 1.0.0
> Configuration
> Plone 2.5.3-final,
> CMF-1.6.4,
> Python 2.6
> PIL 1.1.6
> Mailman 2.1.9
> Postfix 2.4.5
> Basemap: 1.0
> Matplotlib: 1.0.0
