[Qgis-user] SIP problem on startup
John washakie at gmail.com
Thu Feb 17 01:53:52 PST 2011
Ah, okay... done. Now the SIP problem returns :/
Couldn't load PyQGIS.
Python support will be disabled.
  File "", line 1, in
RuntimeError: the sip module implements API v8.0 but the qgis.core
module requires API v7.1
Python version:
2.6.6 (r266:84292, Sep 15 2010, 16:41:53)
[GCC 4.4.5]
QGIS version:
1.7.0-Trunk 'Trunk', 15175M
it seems I need to 'downgrade' my SIP module, or could a patch be
included in the nightly build to lessen the restriction? It seems a
check is being done to confirm that the SIP module is v7.1, is it
necessary that it can be set to be "at least" 7.1?
--john
On Thu, Feb 17, 2011 at 10:08 AM, Noli Sicad <nsicad at gmail.com> wrote:
> Hi John,
> You have to install python-qgis, then you will have "Fetch Python
> Plugin" in Plugin Menubar as first menu item.
> Noli
> On 2/17/11, John <washakie at gmail.com> wrote:
>> Thanks Noli,
>> Yes, Ubuntu 10.10
>> Trunk seems to be working for me, at least I don't get the error
>> message. Is there a way to test though?
>> Also, shouldn't I have a menu option: Plugins > Install Plugins? I
>> only have "Manage Plugins". How do I install new plugins?
>> Sorry for my ignorance,
>> john
>> On Thu, Feb 17, 2011 at 1:05 AM, Noli Sicad <nsicad at gmail.com> wrote:
>>> John,
>>> I guess this is in Linux i.e. Ubuntu.
>>> The sip module is new and not compatible with qgis.
>>> This is the same problem with this posting below.
>>> http://www.mail-archive.com/qgis-user@lists.osgeo.org/msg08737.html
>>> Noli
>>>> Apologies if this is a double post, but I had some problems with my
>>>> initial list subscription.
>>>> Hello, I'm trying to run QGIS, but I get the following error on start up:
>>>>  File "", line 1, in
>>>> Seems rather critical to have Python support.
>>>> Does anyone have any ideas?
>>>> Regards,
>>>> john
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Configuration
>> Plone 2.5.3-final,
>> CMF-1.6.4,
>> Zope (Zope 2.9.7-final, python 2.4.4, linux2),
>> Python 2.6
>> PIL 1.1.6
>> Mailman 2.1.9
>> Postfix 2.4.5
>> Procmail v3.22 2001/09/10
>> Basemap: 1.0
>> Matplotlib: 1.0.0
Configuration
Plone 2.5.3-final,
CMF-1.6.4,
Python 2.6
PIL 1.1.6
Mailman 2.1.9
Postfix 2.4.5
Basemap: 1.0
Matplotlib: 1.0.0
