[Qgis-user] SIP problem on startup
Noli Sicad
nsicad at gmail.com
Thu Feb 17 01:08:20 PST 2011
Hi John,
You have to install python-qgis, then you will have "Fetch Python
Plugin" in Plugin Menubar as first menu item.
Noli
On 2/17/11, John <washakie at gmail.com> wrote:
> Thanks Noli,
> Yes, Ubuntu 10.10
> Trunk seems to be working for me, at least I don't get the error
> message. Is there a way to test though?
> Also, shouldn't I have a menu option: Plugins > Install Plugins? I
> only have "Manage Plugins". How do I install new plugins?
> Sorry for my ignorance,
> john
> On Thu, Feb 17, 2011 at 1:05 AM, Noli Sicad <nsicad at gmail.com> wrote:
>> John,
>> I guess this is in Linux i.e. Ubuntu.
>> The sip module is new and not compatible with qgis.
>> This is the same problem with this posting below.
>> http://www.mail-archive.com/qgis-user@lists.osgeo.org/msg08737.html
>> Noli
>>> Apologies if this is a double post, but I had some problems with my
>>> initial list subscription.
>>> Hello, I'm trying to run QGIS, but I get the following error on start up:
>>> Couldn't load PyQGIS.
>>> Python support will be disabled.
>>> Traceback (most recent call last):
>>> File "", line 1, in
>>> RuntimeError: the sip module implements API v8.0 but the qgis.core
>>> module requires API v7.1
>>> Seems rather critical to have Python support.
>>> Does anyone have any ideas?
>>> Regards,
>>> john
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Configuration
> Plone 2.5.3-final,
> CMF-1.6.4,
> Zope (Zope 2.9.7-final, python 2.4.4, linux2),
> Python 2.6
> PIL 1.1.6
> Mailman 2.1.9
> Postfix 2.4.5
> Procmail v3.22 2001/09/10
> Basemap: 1.0
> Matplotlib: 1.0.0
