[Qgis-user] How to use "Capture points" on OS X?
Ricardo Filipe Soares Garcia da ricardo.garcia.silva at gmail.com
Thu Feb 17 10:46:21 PST 2011
Hi Kirk
In QGIS only one geometry type is allowed per vector layer.
According to your description, it seems you have an already existent
lines layer. You cannot add new points to it, only lines. That is why
you cannot see the 'capture point' button on the editing toolbar.
The solution is to create a new vector layer, of type 'point' and then
turning the edit mode on. Your 'capture point' button will be visible
then ;)
On Thu, Feb 17, 2011 at 6:08 PM, Kirk Wythers <kwythers at umn.edu> wrote:
> I am trying to add a several simple points to a vector layer of North America (to represent site locations). It appears from the documentation that the work flow should be:
> Toggle editing to "on"
> Use Capture point to place the point
> Enter attribute values
> If this is correct, I am stuck in that I can't seem to locate the Capture point button. I can turn on editing, and see the Capture line and move feature buttons. Any suggestions as to where I should look for the Capture point button.
> I am running QGIS 1.6 on OS X snow leopard.
> Thanks
> Qgis-user mailing list
___________________________ ___ __
Ricardo Garcia Silva
