[Qgis-user] FTOOLS Calculate Area error
Paolo Cavallini cavallini at faunalia.it
Fri Feb 18 00:34:58 PST 2011
Il giorno mer, 16/02/2011 alle 21.30 +0100, enricofiore at libero.it ha
scritto:
> Hi,
> I try to calculate area with ftools add geometry column. I have noted that in
> automatic new field “AREA” have this properties type=real lenght=10
> precision=6, this involve an error, some numbers are lost, because the Area
> number have lenght>10.
> Example: if I calculate Piedmont area with Ftools obtain 2539107283
> if I calculate the same Area , add new column (type real lenght=20
> precision=5) and use calc field ($area) I obtain 25391072834.9971.
Hi Enrico.
Thanks for the report. Have you checked that there is no ticket open on
this? If not, please open one, not to miss this issue.
All the best.
http://www.faunalia.it/pc
