[Qgis-user] qgis/osgeo4w error after update
Jürgen E. Fischer
jef at norbit.de
Sat Feb 19 08:45:19 PST 2011
Hi Giovanni,
On Fri, 18. Feb 2011 at 11:30:56 +0000, Giovanni Manghi wrote:
> I just made a new fresh installation on a Seven machine (no other
> software installed) and I still get the same message.
Please check qgis.exe with depends[1]. qgis.exe is located in
OSGeo4W\apps\qgis-dev\bin and you also need to add OSGeo4W\bin to the module
path in depends (Options menu, Configure Module Search Order, Browse..., Add
Directory).
I'd expect that you find some DLL in system32, that also has a different
version in OSGeo4W bin (maybe PostgreSQL or SSL). Removing it from or renaming
it in system32 will then probably cure that problem for QGIS.
Jürgen
[1] http://dependencywalker.com/depends22_x86.zip
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
