[Qgis-user] Send us your tips!
Andreas Neumann
a.neumann at carto.net
Sun Feb 20 23:43:23 PST 2011
Hi Tim
Where should people who are not developers send the tips to? To you?
Here is one contribution:
Title: Add the current date to a map layout
Content: You can add a current date variable to your map layout. Create
a regular text label and add the string $CURRENT_DATE(yyyy-MM-dd) to the
text box. See the <a
href="http://doc.qt.nokia.com/latest/qdate.html#toString">QDate::toString
format documentation</a> for the possible date formats.
Andreas
On Sat, 19 Feb 2011 12:02:15 +0200, Tim Sutton wrote:
> Hi
> Yesterday I added a 'tip of the day' type dialog that appears when
> QGIS starts. You have probably have seen a similar feature in other
> applications. And no, before you ask, we are not going to implement a
> 'Mr. Paperclip' function next :-). Right now the tip list is rather
> basic so I would like to invite everyone to submit your favourite
> little tips for QGIS. Here are some guidelines:
> - The tip should have a short title
> - The tip content should be short - one or two paragraphs
> - Simple HTML formatting can be used for the tip, including links,
> lists etc.
> - Tips should be broadly useful and perhaps reveal functionality that
> users may have otherwise overlooked.
> Here is an example submission:
> Title: Quick access to project properties
> Content: You can quickly access the project properties dialog by
> clicking on the icon in the bottom right corner of the window in the
> status bar area.
> If you are a developer, you can add tips directly to
> src/app/qgstipfactory.cpp - it should be self explanatory what to do
> when you look at the source.
> Regards
> Tim
> Tim Sutton - QGIS Project Steering Committee Member (Release
> Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
> Qgis-user mailing list
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
