[Qgis-user] Error with Home Range plug-in
Giovanni Manghi
giovanni.manghi at gmail.com
Wed Feb 23 02:50:57 PST 2011
> The plugin requires the installation of R and several R modules.
on windows is more complicated than that
First you need to use R < 2.12 because since 2.12 the R binaries are
installed in a different relative location and the rpy2 library (windows
version) wasn't yet updated yet.
If you are on XP then you are almost done, needing just to install a few
R libraries (with dependencies): adehabitat, rgdal, gpclib, shapefiles
If you are on Vista/Seven there is one more annoying thing:
R installs the libraries in a folder called
C:\Users\username\Documents\R\win-library\2.x
but then the plugin (the HR one, like others that R based) looks into
C:\Users\username\R\win-library\2.x
You then need to copy the installed libraries in the "right" folder.
After that it all works fine.
cheers
-- Giovanni --
On Wed, 2011-02-23 at 08:34 +0100, Paolo Cavallini wrote:
> See http://faunalia.it/animove for details
> All the best.
> Il giorno mar, 22/02/2011 alle 21.38 +0000, Manuel SpĂnola ha scritto:
> > Dear list members,
> > R 12.2.1 and QGIS 1.6 Windows plataform.
> > I got the following error trying to install the home range plug-in.
