[Qgis-user] Error with Home Range plug-in
Václav Řehák
rehakv01 at gmail.com
Wed Feb 23 04:11:46 PST 2011
2011/2/23 Giovanni Manghi <giovanni.manghi at gmail.com>:
> Hi,
>> The plugin requires the installation of R and several R modules.
> on windows is more complicated than that
> First you need to use R < 2.12 because since 2.12 the R binaries are
> installed in a different relative location and the rpy2 library (windows
> version) wasn't yet updated yet.
> If you are on XP then you are almost done, needing just to install a few
> R libraries (with dependencies): adehabitat, rgdal, gpclib, shapefiles
> If you are on Vista/Seven there is one more annoying thing:
> R installs the libraries in a folder called
> C:\Users\username\Documents\R\win-library\2.x
> but then the plugin (the HR one, like others that R based) looks into
> C:\Users\username\R\win-library\2.x
> You then need to copy the installed libraries in the "right" folder.
> After that it all works fine.
And you also need to add C:\Program Files\R\R-2.10.1\bin\ (or whatever
version of R you end up installing) to PATH enviroment variable.
Paolo, can you or someone from Faunalia add this information to HR
plugin wiki [0] ? I think it is quite frequent source of errors.
And also, is there any way how to navigate from Animove web [1] to the
wiki [0]? There are some links to the old wiki [2] and trac [3] but I
find it very easy to get lost between all those sites without ever
reaching [0].
[0] http://www.qgis.org/wiki/HomeRange_plugin
[1] http://faunalia.it/animove
[2] https://wiki.faunalia.it/dokuwiki/doku.php?id=public:animove_howto
[3] https://trac.faunalia.it/animove/
