[Qgis-user] Error with Home Range plug-in
Anne Ghisla a.ghisla at gmail.com
Thu Feb 24 02:03:47 PST 2011
On Wed, 2011-02-23 at 13:11 +0100, Václav Řehák wrote:
> 2011/2/23 Giovanni Manghi <giovanni.manghi at gmail.com>:
> > Hi,
> >> The plugin requires the installation of R and several R modules.
> > on windows is more complicated than that
> > First you need to use R < 2.12 because since 2.12 the R binaries are
> > installed in a different relative location and the rpy2 library (windows
> > version) wasn't yet updated yet.
> > If you are on XP then you are almost done, needing just to install a few
> > R libraries (with dependencies): adehabitat, rgdal, gpclib, shapefiles
> > If you are on Vista/Seven there is one more annoying thing:
> > R installs the libraries in a folder called
> > C:\Users\username\Documents\R\win-library\2.x
> > but then the plugin (the HR one, like others that R based) looks into
> > C:\Users\username\R\win-library\2.x
> > You then need to copy the installed libraries in the "right" folder.
> > After that it all works fine.
> And you also need to add C:\Program Files\R\R-2.10.1\bin\ (or whatever
> version of R you end up installing) to PATH enviroment variable.
> Paolo, can you or someone from Faunalia add this information to HR
> plugin wiki [0] ? I think it is quite frequent source of errors.
Hi all,
Thanks for providing these tips, I updated the wiki page accordingly. I
hope it is clear enough, feel free to improve it.
> And also, is there any way how to navigate from Animove web [1] to the
> wiki [0]? There are some links to the old wiki [2] and trac [3] but I
> find it very easy to get lost between all those sites without ever
> reaching [0].
Indeed, it is not straightforward. The help button of the interface
links to the wiki page [0] directly, as it is the main source of updated
information. Paolo, is it possible to reduce the number of redirects?
thanks and regards,
Anne
> [0] http://www.qgis.org/wiki/HomeRange_plugin
> [1] http://faunalia.it/animove
> [2] https://wiki.faunalia.it/dokuwiki/doku.php?id=public:animove_howto
> [3] https://trac.faunalia.it/animove/
http://wiki.osgeo.org/wiki/User:Aghisla
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110224/815f192f/attachment.sig>
