[Qgis-user] Re:Newbie question - gml files
    Sam Vekemans
    acrosscanadatrails at gmail.com
    Sun Jan  2 12:50:44 PST 2011
Ok, i tried the big bad ogr2ogr.exe and got an error
http://picasaweb.google.com/lh/photo/jBGtPGH81IaE3YFb5Tf70A?feat=directlink
And the link on the wiki is broken :(
http://www.qgis.org/wiki/Ogr2ogr
Could anyone explain 'what' this problem actually is? ... is it the way that
i am opening up the .gml file from qgis?
I think that i need to set the project 'projection'  1st.   And i think i
did that, setting it to 'NAD83 (CSRS) EPSG : 4617'
so it says "+proj=longlat +ellps=GRS80 +no_defs"
...  the .shp file opens up with the right projection.
And apparently qgis 'should' be able to open up this .gml file without using
ogr2ogr.exe
I think it's because i dont have postGISgrass or ArcGIS? installed, or
perhaps it's some python library file which is not installed correctly?
Thanks,
Sam
On Sun, Jan 2, 2011 at 11:44 AM, Andrea Peri <aperi2007 at gmail.com> wrote:
> >P.S, if anyone is bored, my task is rather simple.
> >Download all of the canvec .gml files, then convert them to .shp format
> >and save each map feature as a separate .shp file (province size)
> >... then zip and upload it to some website, like mediafire.com or any other
> >file sharing site.
> Hi,
> you could try with gdal/ogr.
> I think the last version is capable to convert GML.
> ogr2ogr.exe -f "ESRI Shapefile" folder-result file.gml
> Regards,
> Andrea Peri
> qwerty àèìòù
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110102/46598f95/attachment.html>
