[Qgis-user] Re:Newbie question - gml files
Sam Vekemans
acrosscanadatrails at gmail.com
Sun Jan 2 18:39:14 PST 2011
Ok, the good news is that QGis 1.6.0 installed good (on my other desktop
PC) after removing the old versions, and ensuring that it is installed on
the c: drive :)
... and then trying to csrs
the bad news is that the map projection is still off.
So i try
ogr2ogr.exe -f "ESRI Shapefile" -t_srs EPSG:4326 c:\try4-gdal NL_LX.gml
and
ogr2ogr.exe -f "ESRI Shapefile" -t_srs EPSG:4617 c:\try4-gdal NL_LX.gml
according to the ogr web page
*-a_srs** srs_def*:Assign an output SRS *-t_srs** srs_def*:Reproject/transform
to this SRS on output *-s_srs** srs_def*: Override source SRS
I tried each of them, and still doesnt work :( and removing the projection
key gets the wrong projection.
Thanks,
Sam
On Sun, Jan 2, 2011 at 4:29 PM, Noli Sicad <nsicad at gmail.com> wrote:
> I think you have to install QGIS in C drive to avoid this problem of
> not finding the Qtcore4.dll.
> Noli
> On 1/3/11, Sam Vekemans <acrosscanadatrails at gmail.com> wrote:
> > That makes sence.
> > Since there are older versions running, the program doesn't know where
> > to turn to, to look for the files :)
> > ... also, i have the programs running on the d: drive rather than the
> > c: drive, so that will also make a difference. I need to clean up my
> > hard drive anyway as this program needs alot of space to work in.
> > cheers,
> > sam
> > On 1/2/11, Noli Sicad <nsicad at gmail.com> wrote:
> >> Hi Sam,
> >> I think you have to uninstall the previous installation of QGIS in Add
> >> / Remove or in Uninstall QGIS (I am not using Windows right now so I
> >> don't exactly know). If not remove manually the QGIS directory and
> >> install again.
> >> QtCore4.dll is Qt library for Qt window toolkit which included in
> >> QGIS. QGIS will not work without the dynamic library.
> >> FWTools is not part of the QGIS, you don't probably need it if you
> >> have work the org2org.exe program in gdal already.
> >> Noli
> >>> thanks
> >>> will try 4326 instead .... and just remove that last program that
> >>> doesnt help. :)
> >>> cheers,
> >>> sam
> >>>> Hi,
> >>>>> it took some time to number crunch, but it did make a whole bunch of
> >>>>> .shp
> >>>>> files :) ... accept the projection is still off.
> >>>>> So i need to add "EPSG : 4617" or some random 4 digit number that
> >>>>> will
> >>>>> work.
> >>>>> ogr2ogr.exe -f "ESRI Shapefile" -t_srs EPSG:4617 d:\try3-gdal
> NL_LX.gml
> >>>>> What i dont know is exactly which projection code to use or the
> prefix
> >>>>> to
> >>>>> use for it. http://www.gdal.org/ogr2ogr.html assumes that the user
> >>>>> already
> >>>>> knows how to use the program :)
> >>>>> ... if i get this right then there is no need to mess with qgis :-)
> >>>> Try,
> >>>> EPSG: 4326 for WGS84
> >>>> http://nsidc.org/data/atlas/epsg_4326.html
> >>>> This is the metafile of one of the file.
> >>>> General:
> >>>> Storage type of this layer: GML
> >>>> Source for this layer:
> >>>> /home/noli/Downloads/A_NZ/NL_EN/NL_EN.gml|layername=EN_1360049_0
> >>>> Geometry type of the features in this layer: Point
> >>>> The number of features in this layer: 3
> >>>> Editing capabilities of this layer:
> >>>> Extents:
> >>>> In layer spatial reference system units : xMin,yMin 48.4084,-66.6146 :
> >>>> xMax,yMax 54.472,-55.0224
> >>>> Layer Spatial Reference System:
> >>>> +proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs
> >>>> Noli
> >>> Twitter: @Acrosscanada
> >>> Blogs: http://acrosscanadatrails.posterous.com/
> >>> http://Acrosscanadatrails.blogspot.com
> >>> Facebook: http://www.facebook.com/sam.vekemans
> >>> Skype: samvekemans
> >>> IRC: irc://irc.oftc.net #osm-ca Canadian OSM channel (an open chat
> room)
> >>> @Acrosscanadatrails
> > Skype: samvekemans
> > IRC: irc://irc.oftc.net #osm-ca Canadian OSM channel (an open chat room)
> > @Acrosscanadatrails
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110102/5f5afcec/attachment.html>
