[Qgis-user] Re:Newbie question - gml files
Sam Vekemans acrosscanadatrails at gmail.com
Sun Jan 2 19:44:08 PST 2011
The command line projection setting doesnt do anything, just causes and
error.
So now im trying  qgis, and using verious combinations.   least im able to
change the projection of the .shp files around, and this .gml file does move
around when i change the projection.
According to this,
http://geogratis.cgdi.gc.ca/geogratis/en/faq.html#q6
it could also be NAD27 ... the projection does change when you get further
north to the arctic circle.
Now that at least the .gml file can be directly converted to .shp (with the
wrong projection)  i can at least play around and try to find the best match
thanks,
sam
On Sun, Jan 2, 2011 at 7:00 PM, Noli Sicad <nsicad at gmail.com> wrote:
> Try, EPSG:3348
> http://webcache.googleusercontent.com/search?q=cache:AF7VwW2DuNoJ:spatialreference.org/ref/epsg/3348/+epsg+canada&cd=2&hl=en&ct=clnk&gl=au
> Noli
> On 1/3/11, Sam Vekemans <acrosscanadatrails at gmail.com> wrote:
> > Hi,
> > Ok, the good news is that QGis 1.6.0 installed good (on my other desktop
> > PC)  after removing the old versions, and ensuring that it is installed
> on
> > the c: drive :)
> > ... and then trying to csrs
> > the bad news is that the map projection is still off.
> > So i try
> > ogr2ogr.exe -f "ESRI Shapefile" -t_srs EPSG:4326 c:\try4-gdal NL_LX.gml
> > and
> > ogr2ogr.exe -f "ESRI Shapefile" -t_srs EPSG:4617 c:\try4-gdal NL_LX.gml
> > according to the ogr web page
> > *-a_srs** srs_def*:Assign an output SRS *-t_srs**
> > srs_def*:Reproject/transform
> > to this SRS on output *-s_srs** srs_def*: Override source SRS
> > I tried each of them, and still doesnt work :(  and removing the
> projection
> > key  gets the wrong projection.
> > Thanks,
> > Sam
> > On Sun, Jan 2, 2011 at 4:29 PM, Noli Sicad <nsicad at gmail.com> wrote:
> >> I think you have to install QGIS in C drive to avoid this problem of
> >> not finding the Qtcore4.dll.
> >> Noli
> >> > That makes sence.
> >> > Since there are older versions running, the program doesn't know where
> >> > to turn to, to look for the files :)
> >> > ... also, i have the programs running on the d: drive rather than the
> >> > c: drive, so that will also make a difference. I need to clean up my
> >> > hard drive anyway as this program needs alot of space to work in.
> >> > cheers,
> >> > sam
> >> > On 1/2/11, Noli Sicad <nsicad at gmail.com> wrote:
> >> >> Hi Sam,
> >> >> I think you have to uninstall the previous installation of QGIS in
> Add
> >> >> / Remove or in Uninstall QGIS (I am not using Windows right now so I
> >> >> don't exactly know). If not remove manually the QGIS directory and
> >> >> install again.
> >> >> QtCore4.dll is Qt library for Qt window toolkit which included in
> >> >> QGIS. QGIS will not work without the dynamic library.
> >> >> FWTools is not part of the QGIS, you don't probably need it if you
> >> >> have work the org2org.exe program in gdal already.
> >> >> Noli
> >> >>> thanks
> >> >>> will try 4326 instead .... and just remove that last program that
> >> >>> doesnt help. :)
> >> >>> cheers,
> >> >>> sam
> >> >>>> Hi,
> >> >>>>> it took some time to number crunch, but it did make a whole bunch
> of
> >> >>>>> .shp
> >> >>>>> files :) ... accept the projection is still off.
> >> >>>>> So i need to add "EPSG : 4617"   or some random 4 digit number
> that
> >> >>>>> will
> >> >>>>> work.
> >> >>>>> ogr2ogr.exe -f "ESRI Shapefile" -t_srs EPSG:4617 d:\try3-gdal
> >> NL_LX.gml
> >> >>>>> What i dont know is exactly which projection code to use or the
> >> prefix
> >> >>>>> to
> >> >>>>> use for it. http://www.gdal.org/ogr2ogr.html assumes that the
> user
> >> >>>>> already
> >> >>>>> knows how to use the program :)
> >> >>>>> ... if i get this right then there is no need to mess with qgis
> >> >>>> Try,
> >> >>>> EPSG: 4326 for WGS84
> >> >>>> http://nsidc.org/data/atlas/epsg_4326.html
> >> >>>> This is the metafile of one of the file.
> >> >>>> General:
> >> >>>> Storage type of this layer: GML
> >> >>>> Source for this layer:
> >> >>>> /home/noli/Downloads/A_NZ/NL_EN/NL_EN.gml|layername=EN_1360049_0
> >> >>>> Geometry type of the features in this layer: Point
> >> >>>> The number of features in this layer: 3
> >> >>>> Editing capabilities of this layer:
> >> >>>> Extents:
> >> >>>> In layer spatial reference system units : xMin,yMin
> 48.4084,-66.6146
> >> >>>> xMax,yMax 54.472,-55.0224
> >> >>>> Layer Spatial Reference System:
> >> >>>> +proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs
> >> >>>> Noli
> >> >>> Twitter: @Acrosscanada
> >> >>> Blogs: http://acrosscanadatrails.posterous.com/
> >> >>> http://Acrosscanadatrails.blogspot.com
> >> >>> Facebook: http://www.facebook.com/sam.vekemans
> >> >>> Skype: samvekemans
> >> >>> IRC: irc://irc.oftc.net #osm-ca Canadian OSM channel (an open chat
> >> room)
> >> >>> @Acrosscanadatrails
> >> > Skype: samvekemans
> room)
> >> > @Acrosscanadatrails
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110102/cb904149/attachment.html>
