[Qgis-user] Re: Newbie question - gml files
Sam Vekemans
acrosscanadatrails at gmail.com
Mon Jan 3 00:12:22 PST 2011
On Sun, Jan 2, 2011 at 10:09 PM, Tyler Mitchell (OSGeo) <tmitchell at osgeo.org
> wrote:
> Have you tried installing ms4w or fwtools and using the ogr2ogr command
> line
> tool to convert?
nope, not yet. Do these run automatically in the background?
and are these installed in QGIS 1.6? If not, then perhaps they can be
added for the 1.7 version?
> Lots of examples in my book (if you have it),
Where do i download your book?
> otherwise
> something like this:
> mkdir shp
> ogr2ogr shp NL_BS/NL_BS.gml
> --- converts from gml into shapefile format in a folder called shp.
> ogr2ogr
> converts by default into shapefile.
Thanks, but i get this error
http://picasaweb.google.com/lh/photo/a3GY5f8JWbcEVI25ICM2MQ?feat=directlink
then staying in the same directory, i get this error
http://picasaweb.google.com/lh/photo/AY_DLof5Y4Fd4chwR4DOEA?feat=directlink
> This seemed to work for me! Ran for a minute, gave a few errors about
> geometry type "Surface", but otherwise looks okay I think. I'm not that
> familiar with the data.
> Not sure, but I'd bet that ogr2ogr is distributed with QGIS on Windows...
I bet it is too .... yet it does not work and change the projection of the
data. :)
> Hope it helps,
> Tyler
Thanks anyway, i'll try installing these programs and assume they work in
the background automatically.
cheers.
sam
> On January 2, 2011 11:08:46 am you wrote:
> > Hi,
> > 1st off, WOW im just exploring the version that does work.
> > Quantum GIS - Mimas, and it's awesome :)
> > Apparently the .gml files from canvec is supposed to work with Copiapo
> > 1.6.0 to be able to open up these .gml files
> > http://ftp2.cits.rncan.gc.ca/pub/canvec/province_gml/nl/
> > (Tyler said it does open up fine)
> > However, i get the error
> > "Entry Point Not Found"
> > The procedure entry point ?next ...... (code) could not be located in the
> > dynamic library QtCor4.dll
> > In english, that means that i dont have Qt installed and running. (I
> don't
> > really want to install it, sorry). Im using windows XP.. .. I'll go
> ahead
> > and install it, but only if i need to.
> > So the solution is to back-track the the version 1.5.0, so i installed
> > that, and got the same error.
> > I'll try version 1.4.0 and see if that works. .. no luck, i don't know
> how
> > to compile the TAR file
> > http://download.osgeo.org/qgis/src/qgis_1.4.0.tar.gz
> > Thanks,
> > Sam
> > P.S, if anyone is bored, my task is rather simple.
> > Download all of the canvec .gml files, then convert them to .shp format
> > and save each map feature as a separate .shp file (province size)
> > ... then zip and upload it to some website, like mediafire.com or any
> other
> > file sharing site.
> > Where the file becomes bigger than 200 megs (zip compressed), (as a
> single
> > map feature), geographycally slice the file into smaller components. (I
> > know that OpenJUMP can do this, but it would be fun to have it all in the
> > same software..
> > .... so at minimun. all i need is to be able to Open up the .gml file so
> > it's in the same map-projection as the canvec NTS .shp files, and save
> them
> > on my hard-drive as a .shp file, then i can work with it from there...
> > This is an example of the canvec .gml file that got converted using
> > mygeodata.eu and loaded to koordinates.com
> http://picasaweb.google.com/lh/photo/PGD9dGCvIVAHwC5kHHqHOg?feat=directlink
> > and here's the example showing the .gml file, (and the .shp file which is
> > correct) loaded to QGIS Mimas
> http://picasaweb.google.com/lh/photo/DPc4KpmlEWSytHidIR7pLA?feat=directlink
> > I'll keep on trying, other options, and dig through the archives, as
> > perhaps someone else has had this problem before.
> > Cheers,
> > Sam
> > Across Canada Trails - Beyond 2017 - The National Trails Network
> > Victoria, BC Canada
> > Twitter: @Acrosscanada
> > Blog: http://acrosscanadatrails.posterous.com/
> > Facebook: http://www.facebook.com/sam.vekemans
> > Skype: 'Sam Vekemans'
> > Member, CommonMap Inc. http://commonmap.org/
> > IRC: irc://irc.oftc.net #CommonMap
> > Also find us on Facebook, Twitter and LinkedIn
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110103/5fa961ff/attachment.html>
