AW: [Qgis-user] plugin easyprint
Ziegler Stefan
Stefan.Ziegler at bd.so.ch
Tue Jan 4 06:03:02 PST 2011
Hi
do you really get "/" as delimiter? I use hardcoded "." in the plugin code. I changed the language in QGIS to french, englisch and german. All the time I get ".".
I will add the possibility to change "Bearbeiter" in layout file hopefully today or tomorrow.
regards
Stefan
Mit freundlichem Gruss
Stefan Ziegler
Leiter amtliche Vermessung
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
032 627 75 96
----- Originalnachricht -----
Von: "jonathan ALLAIN" <j.allain at agglo-paysflers.fr>
Gesendet: Die, 4.1.2011 12:13
An: qgis-user at lists.osgeo.org
Betreff: [Qgis-user] plugin easyprint
Bonjour,
J’utilise le plugin easy print, cependant la date est au format anglais mm/jj/aaaa, je souhaiterais passer la date au format français.
En outre, le texte « bearbeiter » n’apparait pas dans le fichier layout.xml. Je souhaiterais également passer ce texte en français.
Merci pour vos conseils.
Hello,
I use the plugin easy print, however the date is in English format mm / dd / yyyy, I would move the date in French format dd/mm/yyyy.
In addition, the text "Bearbeiter" does not appear in the file layout.xml. I would also like to pass this text into French.
Thank you for your advice.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
