AW: AW: [Qgis-user] plugin easyprint
    Ziegler Stefan
    Stefan.Ziegler at bd.so.ch
    Sun Jan 16 23:02:12 PST 2011
Hi Jonathan
with the latest update you should be able to change "Bearbeiter" to
whatever you want in the layouts.xml.
regards
Stefan
> -----Ursprüngliche Nachricht-----
> Von: Ziegler Stefan
> Gesendet am: Dienstag, 4. Januar 2011 15:03
> An: jonathan ALLAIN; qgis-user at lists.osgeo.org
> Betreff: AW: [Qgis-user] plugin easyprint
> Hi
> do you really get "/" as delimiter? I use hardcoded "." in
> the plugin code. I changed the language in QGIS to french,
> englisch and german. All the time I get ".".
> I will add the possibility to change "Bearbeiter" in layout
> file hopefully today or tomorrow.
> regards
> Stefan
> Mit freundlichem Gruss
> Stefan Ziegler
> Leiter amtliche Vermessung
> Amt für Geoinformation
> Rötistrasse 4
> 4501 Solothurn
> 032 627 75 96
> ----- Originalnachricht -----
> Von: "jonathan ALLAIN" <j.allain at agglo-paysflers.fr>
> Gesendet: Die, 4.1.2011 12:13
> An: qgis-user at lists.osgeo.org
> Betreff: [Qgis-user] plugin easyprint
> Bonjour,
> J'utilise le plugin easy print, cependant la date est au
> format anglais mm/jj/aaaa, je souhaiterais passer la date au
> format français.
> En outre, le texte « bearbeiter » n'apparait pas dans le
> fichier layout.xml. Je souhaiterais également passer ce texte
> en français.
> Merci pour vos conseils.
> Hello,
> I use the plugin easy print, however the date is in English
> format mm / dd / yyyy, I would move the date in French format
> dd/mm/yyyy.
> In addition, the text "Bearbeiter" does not appear in the
> file layout.xml. I would also like to pass this text into French.
> Thank you for your advice.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110117/cf8d0d5b/attachment.html>
