[Qgis-user] Missing primary key.
Noli Sicad
nsicad at gmail.com
Sat Jan 8 14:17:24 PST 2011
I think this is the same problem being discussed in Postgis ML. See the archive,
[postgis-users] OIDS, PostGIS and Quantum GIS
http://www.mail-archive.com/postgis-users@postgis.refractions.net/msg07446.html
Noli
On 1/9/11, Byron Como <bcomo at cox.net> wrote:
> On 1/8/2011 3:15 PM, Jürgen E. Fischer wrote:
>> [please keep the thread on the list. And if you want to do me a favor,
>> use
>> plain text and reply inline]
>> Hi Byron,
>> On Sat, 08. Jan 2011 at 11:30:22 -0600, Byron Como wrote:
>>> On 1/8/2011 11:19 AM, Jürgen E. Fischer wrote:
>>>> Maybe you had oids before?
>>> Nope, only the geometry table uses oids. The data tables all have gid,
>>> ineger, as the primary key. In pgadmin the data can be manipulated
>>> normally -
>>> copied, pasted, deleted and all the columns are correct.
>> So you have oids on the geometry table you try to insert, but QGIS is
>> still
>> complaining?
> That is correct.
>>> The data was created on Windows Xp, Postgresql 8.4, Quantum GIS 1.5.
>>> Several
>>> times the data had to be restored to the Windows XP setup for various
>>> reasons
>>> including a lightning strike. The restore process worked correctly each
>>> time.
>>> The current broken setup is on a Windows 7 box, Postgresql 8.4, PostGIS
>>> 1.4,
>>> and Quantum GIS 1.5 and 1.6 have been tried.
>> On Sat, 08. Jan 2011 at 14:37:27 -0600, Byron Como wrote:
>>> On 1/8/2011 2:29 PM, Jürgen E. Fischer wrote:
>>>> The python included in the standalone installer should work. Are you
>>>> trying to make it use your python 2.7 installation? If so, that might
>>>> cause the problem.
> I deleted the 2.7 installation and installed 2.5 (see below).
>>> Ah, here's where the whole episode gets murky. The error message occurred
>>> after installing using the 'simplified' installer - before I installed
>>> any
>>> extra python software. I decided to install the extra python and psycopg2
>>> packages after failing to find any good suggestions on resolving the
>>> problem searching Google. Your feed back is helpful. Now I know I don't
>>> need the extra python packages. Then is the problem an evironment
>>> variable
>>> setting?
>> Do you have PostgreSQL installed locally? Were PostgreSQL directories
>> added to
>> the PATH or installed in %WINDIR%\system32. That might interfere.
> PostgreSQL is in c:\program files (x86)
> My path statement is:
> PATH=C:\OSGeo4W\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;
> C:\Windows\System32\WindowsPowerShell\v1.0\;C:\OSGeo4W\apps\msys\bin
>> Try "import psycopg2" in the python console (or a python started from the
>> OSGeo4W shell). It's output might shed some light on the problem.
> >>> import psycopg2
> >>> psycopg2
> <module 'psycopg2' from
> 'C:\OSGeo4W\apps\Python25\lib\site-packages\psycopg2\__init__.pyc'>
>> Maybe it's not just a python problem and is somehow related to the primary
>> key
>> problem.
>> Jürgen
> I installed Qgis 1.5 using the 'simplified' installer.
> Got a strange 'can't find the psycopg2' file from PostGis Manager.
> To fix THAT error I did:
> Installed Python 2.5.4
> Installed psycop2.2.2w32
> Copied the resulting psycop2 directory into the
> C:\Program Files (x86)\Quantum GIS
> Tethys\apps\Python25\Lib\site-packages\psycopg2
> ...and the error message went away.
> The missing primary key is occurring in v1.5 and 1.6 using the
> simplified install and the 1.6 OSGeo4W install.
> All this to try and use Quantum GIS on Windows 7 64 bit.
