[Qgis-user] Missing primary key.
Byron Como
bcomo at cox.net
Sat Jan 8 15:16:19 PST 2011
On 1/8/2011 5:06 PM, Jürgen E. Fischer wrote:
> On Sat, 08. Jan 2011 at 16:06:20 -0600, Byron Como wrote:
>> On 1/8/2011 3:15 PM, Jürgen E. Fischer wrote:
>>> So you have oids on the geometry table you try to insert, but QGIS is still
>>> complaining?
>> That is correct.
> Strange.
>>> I deleted the 2.7 installation and installed 2.5 (see below).
> You don't need to install 2.5. You already installed it with QGIS, but having
> other python installations should be a problem either.
>> My path statement is:
>> PATH=C:\OSGeo4W\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\OSGeo4W\apps\msys\bin
> Where did you look that up? The system's PATH should be left alone by the
> INSTALL. So you shouldn't have any "global" OSGeo4W entries there.
That came from path statement executed in the OSGeo4w console. The path
from the windows console doesn't have the OSGeo4W references.
>> Try "import psycopg2" in the python console (or a python started from the
>> OSGeo4W shell). It's output might shed some light on the problem.
>> >>> import psycopg2
>> >>> psycopg2
>> <module 'psycopg2' from
>> 'C:\OSGeo4W\apps\Python25\lib\site-packages\psycopg2\__init__.pyc'>
> Hm, that looks fine - no idea why postgis manager is complaining.
> Jürgen
La la la la la , I am happy, I ah happy, I am happy.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110108/73aa9eff/attachment.html>
