[Qgis-user] Intersection between vector layers
Noli Sicad
nsicad at gmail.com
Sun Jan 23 22:22:28 PST 2011
I got error from the URL
Sorry, the page (or document) you have requested is not available.
Please check the address and try again.
I suppose the yellow polygon and dots are not in the same layer / vector.
You have to merge it to make into 1 layer, then you can select it and clip.
Noli
On 1/24/11, Nicholas.Crosbie at health.vic.gov.au
<Nicholas.Crosbie at health.vic.gov.au> wrote:
> Hi,
> How do I select all points within the yellow polygon - see the following
> screen grab:
> https://docs.google.com/leaf?id=0B30Nq8_lPexjZGY0ZTdjNTktOGE3NC00NjBlLWEwMzEtYjhhY2RjNDhkMDFm&sort=name&layout=list&num=50
> Note that both the yellow polygon and the dots are vector layers (all dots
> contained on one vector layer).
> In my mind this is like a spatial SQL query.
> How do I do this QGIS?
> _________________________________________________________________________________
> This email contains confidential information intended only for the person
> named above and may be subject to legal privilege. If you are not the
> intended recipient, any disclosure, copying or use of this information is
> prohibited. The Department provides no guarantee that this communication is
> free of virus or that it has not been intercepted or interfered with. If you
> have received this email in error or have any other concerns regarding its
> transmission, please notify Postmaster at dhs.vic.gov.au
