[Qgis-user] bug
no-reply blackhole at lobianco.org
Thu Jan 27 00:39:23 PST 2011
"BUG" ?? .. What do you mean, BUnGa-BUnGa... ??!!
Seriously.. my two cents.. try to use a more descriptive title, so people
doesn't mix different things in the same thread... ;-)
On 27 January 2011 08:47, Alister Hood <alister.hood at synergine.com> wrote:
> Hi Sam,
> > Date: Wed, 26 Jan 2011 18:59:12 -0800
> > From: Sam Vekemans <acrosscanadatrails at gmail.com>
> > Subject: Re: [Qgis-user] bug
> > To: "M.E.Dodd" <m.e.dodd at open.ac.uk>
> > Cc: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> > Message-ID:
> >       <AANLkTik_fd4N46bg_m4Y7=4P-Xo_CgHUeCmzZLB2pCST at mail.gmail.com>
> > Content-Type: text/plain; charset="iso-8859-1"
> > Hi,
> > For a moment their i thought that it could solve my problem for not
> > being
> > able to open up qgis 1.6
> > but i still get the same error.
> http://picasaweb.google.com/lh/photo/ZZVhnhDbi8H5tdJZUsbDrQ?feat=direct
> > link
> > However, I found and interesting search results
> http://picasaweb.google.com/lh/photo/xJmzGR2LOYGCaJp9X21Iag?feat=direct
> > link
> > What does Webkit-image actually do?  Is it part of the installer?
> > semi-answered by own question
> > http://en.wikipedia.org/wiki/WebKit
> I read that Webkit-image is a "web browser" which saves an image of a
> Web page (rather than displaying the page).
> I don't know what would have installed it on your machine, but not QGIS.
> But I think this dll shouldn't be a problem... unless C:\webkit-image
> has
> been permanently added to your Windows PATH variable.
> > When i do the full install of qgis 1.6 there is no 'uninstaller' which
> > is
> > available.  I assume that there 'should' be one on install?
> > I dont want to remove the one in the Windows folder, incase it's used
> > to run
> > windows.
> I think you'll find that the one in the Windows folder is causing your
> problem.  QT isn't used by Windows itself, so you could try deleting it,
> to see if that solves the problem.  But you might find that there are
> other related dlls which cause the same problem.
> And presumably this would break whichever program installed the dll.
> If you don't use the offending program it would be good to uninstall it.
> If you do use it, life might be getting more complicated :)
> > and it's also in JOSM and in KDE Marble.
> See above comment about the containing folders being added to the PATH
> variable
> > So could this be the problem?  A conflict of interest for this file?
> > Thanks,
> > Sam
> Regards,
> Alister
> Qgis-user mailing list
Antonello Lobianco
Assegnista di Ricerca
Dipartimento di Economia, Università Politecnica delle Marche
Progetto "RegMAS per il Piceno" (Fondazione CARISAP)
Tel: +39.071.2207116
Email: a.lobianco at univpm.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110127/6345735b/attachment.html>
