[Qgis-user] bug
Alister Hood
alister.hood at synergine.com
Wed Jan 26 23:47:40 PST 2011
Hi Sam,
> Date: Wed, 26 Jan 2011 18:59:12 -0800
> From: Sam Vekemans <acrosscanadatrails at gmail.com>
> Subject: Re: [Qgis-user] bug
> To: "M.E.Dodd" <m.e.dodd at open.ac.uk>
> Cc: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Message-ID:
> <AANLkTik_fd4N46bg_m4Y7=4P-Xo_CgHUeCmzZLB2pCST at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Hi,
> For a moment their i thought that it could solve my problem for not
> being
> able to open up qgis 1.6
> but i still get the same error.
http://picasaweb.google.com/lh/photo/ZZVhnhDbi8H5tdJZUsbDrQ?feat=direct
> link
> However, I found and interesting search results
http://picasaweb.google.com/lh/photo/xJmzGR2LOYGCaJp9X21Iag?feat=direct
> link
> What does Webkit-image actually do? Is it part of the installer?
> semi-answered by own question
> http://en.wikipedia.org/wiki/WebKit
I read that Webkit-image is a "web browser" which saves an image of a
Web page (rather than displaying the page).
I don't know what would have installed it on your machine, but not QGIS.
But I think this dll shouldn't be a problem... unless C:\webkit-image
has
been permanently added to your Windows PATH variable.
> When i do the full install of qgis 1.6 there is no 'uninstaller' which
> is
> available. I assume that there 'should' be one on install?
> I dont want to remove the one in the Windows folder, incase it's used
> to run
> windows.
I think you'll find that the one in the Windows folder is causing your
problem. QT isn't used by Windows itself, so you could try deleting it,
to see if that solves the problem. But you might find that there are
other related dlls which cause the same problem.
And presumably this would break whichever program installed the dll.
If you don't use the offending program it would be good to uninstall it.
If you do use it, life might be getting more complicated :)
> and it's also in JOSM and in KDE Marble.
See above comment about the containing folders being added to the PATH
variable
> So could this be the problem? A conflict of interest for this file?
> Thanks,
> Sam
Regards,
Alister
