[Qgis-user] Is there a way of installing the qgis plugin for ORFEO Toolbox (OTB)?
Alexander Bruy
alexander.bruy at gmail.com
Thu Jan 27 08:32:57 PST 2011
By default in OSGeo4W and qgis-dev all C++ plugins located in
C:\OSGeo4W\apps\qgis-dev\plugins
On Thu, 27 Jan 2011 12:40:31 +0000
Giovanni Manghi <giovanni.manghi at gmail.com> wrote:
> Hi, you have to put it in
> C:\OSGeo4W\apps\qgis\plugins
> I don't remember now (I'm on linux) if the path is 100% but it is easy
> to check: you need to find the folder where you will see all the other C
> plugins (as .dll libraries).
> cheers
> -- Giovanni --
> On Thu, 2011-01-27 at 12:37 +0000, M.E.Dodd wrote:
> > Thanks for this. I've tried a few different ways as suggested on that page but not sure I am doing it right as nothing is obviously appearing, at the moment am trying:
> > "OTB module is available as a separate file , the installation is reduced to the unpacking and transfer dll-library in the directory of extensions installed QGIS."
> > Have downloaded the .dll file and put it in the directory C:\OSGeo4W\bin but not sure if this is correct, should it be in one of the other subdirectories as I can't find one called 'extensions'.
> > -----Original Message-----
> > From: Giovanni Manghi [mailto:giovanni.manghi at gmail.com]
> > Sent: 26 January 2011 20:51
> > To: M.E.Dodd
> > Cc: qgis-user at lists.osgeo.org
> > Subject: Re: [Qgis-user] Is there a way of installing the qgis plugin for ORFEO Toolbox (OTB)?
> > On Wed, 2011-01-26 at 17:01 +0000, M.E.Dodd wrote:
> > > I can find their website and the full Monteverdi program but can't
> > > work out how to install the qgis plugin, any suggestions?
> > Gis-Lab packaged the plugin for windows
> > http://translate.google.com/translate?hl=en&sl=ru&tl=en&u=http://gis-lab.info/blog/2010-11/otb-plugin-qgis/
> > cheers
> > -- Giovanni --
> Qgis-user mailing list
Alexander Bruy
