[Qgis-user] Is there a way of installing the qgis plugin for ORFEO Toolbox (OTB)?
Giovanni Manghi
giovanni.manghi at gmail.com
Thu Jan 27 04:40:31 PST 2011
Hi, you have to put it in
C:\OSGeo4W\apps\qgis\plugins
I don't remember now (I'm on linux) if the path is 100% but it is easy
to check: you need to find the folder where you will see all the other C
plugins (as .dll libraries).
cheers
-- Giovanni --
On Thu, 2011-01-27 at 12:37 +0000, M.E.Dodd wrote:
> Thanks for this. I've tried a few different ways as suggested on that page but not sure I am doing it right as nothing is obviously appearing, at the moment am trying:
> "OTB module is available as a separate file , the installation is reduced to the unpacking and transfer dll-library in the directory of extensions installed QGIS."
> Have downloaded the .dll file and put it in the directory C:\OSGeo4W\bin but not sure if this is correct, should it be in one of the other subdirectories as I can't find one called 'extensions'.
> -----Original Message-----
> From: Giovanni Manghi [mailto:giovanni.manghi at gmail.com]
> Sent: 26 January 2011 20:51
> To: M.E.Dodd
> Cc: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Is there a way of installing the qgis plugin for ORFEO Toolbox (OTB)?
> On Wed, 2011-01-26 at 17:01 +0000, M.E.Dodd wrote:
> > I can find their website and the full Monteverdi program but can't
> > work out how to install the qgis plugin, any suggestions?
> Gis-Lab packaged the plugin for windows
> http://translate.google.com/translate?hl=en&sl=ru&tl=en&u=http://gis-lab.info/blog/2010-11/otb-plugin-qgis/
> cheers
> -- Giovanni --
