[Qgis-user] Using templates in QGIS when importing GPS-data to PostGIS
Yves Jacolin yjacolin at free.fr
Mon Jul 4 01:42:46 PDT 2011
You need an ETL like Talend Open Studio with spatial extension for this or
create some python script inside QGIS.
see http://www.talendforge.org/wiki/doku.php?id=sdi:MainPage for more
information about SDI.
Y.
Le lundi 04 juillet 2011 10:29:31, Pekka Hurskainen a écrit :
> Hello list,
> Let's say I have a bunch of waypoints collected with a GPS device, and
> uploaded to QGIS with GPSBabel in GPX-format. I have only four fields
> in the GPX file which I want to keep (lat, lon, time, name).
> Then I have an empty template shapefile, which has more fields
> defined. Some of them has to be filled interactively in QGIS, some of
> them will be filled by trigger functions in PostGIS. The point is that
> the template shapefile has to match exactly the table definitions in
> my PostGIS database, so that it is possible to append GPS datasets to
> the database using PostGIS Manager plugin. I can't just spit the GPX
> files straight to PostGIS.
> The problem is how to "combine" the GPX points with the template. I've
> tried to merge these two with fTools and mmqgis plugins, but these
> both add all fields from both layers, which I don't want (there isn't
> an option to choose fields). Also I haven't found any "append" tool
> similar to ArcGIS in QGIS.
> I know it's possible to overcome this with manually deleting the
> unwanted fields, but I want to automate the process since this part
> will be repeated hundreds of times.
> Any ideas?
> Pekka Hurskainen
> Qgis-user mailing list
Yves Jacolin
http://yjacolin.gloobe.org
