[Qgis-user] QGis crashing when turning on data labels
Andreas Neumann
a.neumann at carto.net
Mon Jul 4 23:03:17 PDT 2011
Hi Ara,
We would need to know a few more details:
* Did you use the old or the new labeling? The one in the layer
properties tab (the old) or the one with the "ABC" button in the
labeling toolbar with a separate dialogue (the new)?
* Are you able to use the same QGIS project on a different machine with
a different OS (Linux, Windows) - if yes. Does it also crash? - If no -
are you able to reproduce the same behavior on another Mac?
Andreas
On Mon, 4 Jul 2011 17:17:22 -0600, Ara Kooser wrote:
> Hello all,
> I've successfully managed to do a fair amount of QGis in the plast
> couple of days. Thanks to all for the help!
> Right now I am trying to turn on my data labels for a set of survey
> stations on a map I have. I have the shapefile but when I go into the
> layer and turn on the data labels the program crashes and exits.
> There
> is a very long error report from OS X that is generated as well.
> I am running QGis 1.7 on OS X 10.6.7 with 4 Gigs of ram, Intel
> processors. Any suggestions for getting my station id's on? I didn't
> want to put the error log in this e-mail since it is so long.
> Thanks!
> Ara
> Qgis-user mailing list
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
