[Qgis-user] file ecw and mrsid in ubuntu doesn't work
ahmad jauhari mriduan62 at gmail.com
Tue Jul 5 19:10:27 PDT 2011
Dear all,
I have successfully installed the advice of Lee, and I also have
installed the SDKs on the advice of Giovanni, but when I open the file
ECw, qgis immediately close. is there a suggestion.
Thanks,
On Tue, Jul 5, 2011 at 1:09 AM, Lee <muellerl at gmail.com> wrote:
> I did this successfully again today on a fresh install. For ECW the
> following method has worked for me:
> open terminal
> sudo wget
> http://de-mirror.org/distro/gentoo/distfiles/libecwj2-3.3-2006-09-06.zip
> unzip libecwj2-3.3-2006-09-06.zip
> cd libecwj2-3.3
> ./configure
> make
> sudo make install
> sudo gdal-ecw-build /usr/local/ (This step may differ depending on your file
> system)
> sudo ldconfig
> gdalinfo –formats | grep -i ecw
> Make sure in the last step the output shows. If it does not, the install
> failed.
> I still have yet to successfully incorporate MrSID support. If you manage
> it, please let me know.
> On Mon, Jul 4, 2011 at 6:25 AM, Giovanni Manghi <giovanni.manghi at gmail.com>
> wrote:
>> you need the SDKs from erdas and lizardtech
>> cheers
>> -- Giovanni --
>> On Mon, 2011-07-04 at 18:24 +0800, ahmad jauhari wrote:
>> > dear all,
>> > i have installed gdal-ecw-src and gdal-mrsid-src, but qgis program can
>> > not access the file .ecw and file mrSID,  anyone can help me. thanks.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> all the best,
> Lee
