[Qgis-user] file ecw and mrsid in ubuntu doesn't work
Giovanni Manghi giovanni.manghi at gmail.com
Wed Jul 6 09:32:19 PDT 2011
It works fine here, Ubuntu 10.04, qgis 1.7 from the ubuntugis
repository.
Please launch qgis from the terminal and copy/paste here the error
message.
If you can share a sample of your data so we can test if it depends on
data rather than the program/libraries.
cheers
-- Giovanni --
On Wed, 2011-07-06 at 10:10 +0800, ahmad jauhari wrote:
> Dear all,
> I have successfully installed the advice of Lee, and I also have
> installed the SDKs on the advice of Giovanni, but when I open the file
> ECw, qgis immediately close. is there a suggestion.
> Thanks,
> On Tue, Jul 5, 2011 at 1:09 AM, Lee <muellerl at gmail.com> wrote:
> > I did this successfully again today on a fresh install. For ECW the
> > following method has worked for me:
> > open terminal
> > sudo wget
> > http://de-mirror.org/distro/gentoo/distfiles/libecwj2-3.3-2006-09-06.zip
> > unzip libecwj2-3.3-2006-09-06.zip
> > cd libecwj2-3.3
> > ./configure
> > make
> > sudo make install
> > sudo gdal-ecw-build /usr/local/ (This step may differ depending on your file
> > system)
> > sudo ldconfig
> > gdalinfo –formats | grep -i ecw
> > Make sure in the last step the output shows. If it does not, the install
> > failed.
> > I still have yet to successfully incorporate MrSID support. If you manage
> > it, please let me know.
> > On Mon, Jul 4, 2011 at 6:25 AM, Giovanni Manghi <giovanni.manghi at gmail.com>
> > wrote:
> >> you need the SDKs from erdas and lizardtech
> >> cheers
> >> -- Giovanni --
> >> On Mon, 2011-07-04 at 18:24 +0800, ahmad jauhari wrote:
> >> > dear all,
> >> > i have installed gdal-ecw-src and gdal-mrsid-src, but qgis program can
> >> > not access the file .ecw and file mrSID,  anyone can help me. thanks.
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
> > all the best,
> > Lee
