[Qgis-user] file ecw and mrsid in ubuntu doesn't work
Lee muellerl at gmail.com
Wed Jul 6 09:38:20 PDT 2011
Giovanni,
Would you mind posting your procedure for incorporating mrsid support?
all the best,
Lee Mueller
On Jul 6, 2011 12:32 PM, "Giovanni Manghi" <giovanni.manghi at gmail.com>
wrote:
> It works fine here, Ubuntu 10.04, qgis 1.7 from the ubuntugis
> repository.
> Please launch qgis from the terminal and copy/paste here the error
> message.
> If you can share a sample of your data so we can test if it depends on
> data rather than the program/libraries.
> cheers
> -- Giovanni --
> On Wed, 2011-07-06 at 10:10 +0800, ahmad jauhari wrote:
>> Dear all,
>> I have successfully installed the advice of Lee, and I also have
>> installed the SDKs on the advice of Giovanni, but when I open the file
>> ECw, qgis immediately close. is there a suggestion.
>> Thanks,
>> On Tue, Jul 5, 2011 at 1:09 AM, Lee <muellerl at gmail.com> wrote:
>> > I did this successfully again today on a fresh install. For ECW the
>> > following method has worked for me:
>> > open terminal
>> > sudo wget
http://de-mirror.org/distro/gentoo/distfiles/libecwj2-3.3-2006-09-06.zip
>> > unzip libecwj2-3.3-2006-09-06.zip
>> > cd libecwj2-3.3
>> > ./configure
>> > make
>> > sudo make install
>> > sudo gdal-ecw-build /usr/local/ (This step may differ depending on your
file
>> > system)
>> > sudo ldconfig
>> > gdalinfo –formats | grep -i ecw
>> > Make sure in the last step the output shows. If it does not, the
install
>> > failed.
>> > I still have yet to successfully incorporate MrSID support. If you
manage
>> > it, please let me know.
>> > On Mon, Jul 4, 2011 at 6:25 AM, Giovanni Manghi <
>> > wrote:
>> >> you need the SDKs from erdas and lizardtech
>> >> cheers
>> >> -- Giovanni --
>> >> On Mon, 2011-07-04 at 18:24 +0800, ahmad jauhari wrote:
>> >> > dear all,
>> >> > i have installed gdal-ecw-src and gdal-mrsid-src, but qgis program
can
>> >> > not access the file .ecw and file mrSID, anyone can help me. thanks.
>> >> _______________________________________________
>> >> Qgis-user mailing list
>> >> Qgis-user at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> > all the best,
>> > Lee
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110706/0b16b3c2/attachment.html>
