[Qgis-user] file ecw and mrsid in ubuntu doesn't work
Giovanni Manghi giovanni.manghi at gmail.com
Wed Jul 6 11:11:54 PDT 2011
nothing more than described here, and it works
http://trac.osgeo.org/ubuntugis/wiki/TutorialMrSid
you need the old GeoExpress Decode SDK
I used
Version:    7.0.0.2167
Platform:   linux.x86.gcc41
cheers
-- Giovanni --
On Wed, 2011-07-06 at 12:38 -0400, Lee wrote:
> Giovanni,
> Would you mind posting your procedure for incorporating mrsid support?
> all the best,
> Lee Mueller
> On Jul 6, 2011 12:32 PM, "Giovanni Manghi" <giovanni.manghi at gmail.com>
> wrote:
> > It works fine here, Ubuntu 10.04, qgis 1.7 from the ubuntugis
> > repository.
> > Please launch qgis from the terminal and copy/paste here the error
> > message.
> > If you can share a sample of your data so we can test if it depends
> on
> > data rather than the program/libraries.
> > cheers
> > -- Giovanni --
> > On Wed, 2011-07-06 at 10:10 +0800, ahmad jauhari wrote:
> >> Dear all,
> >> I have successfully installed the advice of Lee, and I also have
> >> installed the SDKs on the advice of Giovanni, but when I open the
> file
> >> ECw, qgis immediately close. is there a suggestion.
> >> Thanks,
> >> On Tue, Jul 5, 2011 at 1:09 AM, Lee <muellerl at gmail.com> wrote:
> >> > I did this successfully again today on a fresh install. For ECW
> the
> >> > following method has worked for me:
> >> > open terminal
> >> > sudo wget
> http://de-mirror.org/distro/gentoo/distfiles/libecwj2-3.3-2006-09-06.zip
> >> > unzip libecwj2-3.3-2006-09-06.zip
> >> > cd libecwj2-3.3
> >> > ./configure
> >> > make
> >> > sudo make install
> >> > sudo gdal-ecw-build /usr/local/ (This step may differ depending
> on your file
> >> > system)
> >> > sudo ldconfig
> >> > gdalinfo –formats | grep -i ecw
> >> > Make sure in the last step the output shows. If it does not, the
> install
> >> > failed.
> >> > I still have yet to successfully incorporate MrSID support. If
> you manage
> >> > it, please let me know.
> >> > On Mon, Jul 4, 2011 at 6:25 AM, Giovanni Manghi
> >> > wrote:
> >> >> you need the SDKs from erdas and lizardtech
> >> >> cheers
> >> >> -- Giovanni --
> >> >> On Mon, 2011-07-04 at 18:24 +0800, ahmad jauhari wrote:
> >> >> > dear all,
> >> >> > i have installed gdal-ecw-src and gdal-mrsid-src, but qgis
> program can
> >> >> > not access the file .ecw and file mrSID, anyone can help me.
> thanks.
> >> >> _______________________________________________
> >> >> Qgis-user mailing list
> >> >> Qgis-user at lists.osgeo.org
> >> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
> >> > all the best,
> >> > Lee
