[Qgis-user] file ecw and mrsid in ubuntu doesn't work
Lee muellerl at gmail.com
Wed Jul 6 11:51:50 PDT 2011
I've had trouble finding the correct SDK. The one I've downloaded is a newer
version and requires a different procedure. Where did you find the 4.1 SDK?
On Wed, Jul 6, 2011 at 2:11 PM, Giovanni Manghi
<giovanni.manghi at gmail.com>wrote:
> Hi,
> nothing more than described here, and it works
> http://trac.osgeo.org/ubuntugis/wiki/TutorialMrSid
> you need the old GeoExpress Decode SDK
> I used
> Version:    7.0.0.2167
> Platform:   linux.x86.gcc41
> cheers
> -- Giovanni --
> On Wed, 2011-07-06 at 12:38 -0400, Lee wrote:
> > Giovanni,
> > Would you mind posting your procedure for incorporating mrsid support?
> > all the best,
> > Lee Mueller
> > On Jul 6, 2011 12:32 PM, "Giovanni Manghi" <giovanni.manghi at gmail.com>
> > wrote:
> > > It works fine here, Ubuntu 10.04, qgis 1.7 from the ubuntugis
> > > repository.
> > > Please launch qgis from the terminal and copy/paste here the error
> > > message.
> > > If you can share a sample of your data so we can test if it depends
> > on
> > > data rather than the program/libraries.
> > > cheers
> > > -- Giovanni --
> > > On Wed, 2011-07-06 at 10:10 +0800, ahmad jauhari wrote:
> > >> Dear all,
> > >> I have successfully installed the advice of Lee, and I also have
> > >> installed the SDKs on the advice of Giovanni, but when I open the
> > file
> > >> ECw, qgis immediately close. is there a suggestion.
> > >> Thanks,
> > >> On Tue, Jul 5, 2011 at 1:09 AM, Lee <muellerl at gmail.com> wrote:
> > >> > I did this successfully again today on a fresh install. For ECW
> > the
> > >> > following method has worked for me:
> > >> > open terminal
> > >> > sudo wget
> > http://de-mirror.org/distro/gentoo/distfiles/libecwj2-3.3-2006-09-06.zip
> > >> > unzip libecwj2-3.3-2006-09-06.zip
> > >> > cd libecwj2-3.3
> > >> > ./configure
> > >> > make
> > >> > sudo make install
> > >> > sudo gdal-ecw-build /usr/local/ (This step may differ depending
> > on your file
> > >> > system)
> > >> > sudo ldconfig
> > >> > gdalinfo –formats | grep -i ecw
> > >> > Make sure in the last step the output shows. If it does not, the
> > install
> > >> > failed.
> > >> > I still have yet to successfully incorporate MrSID support. If
> > you manage
> > >> > it, please let me know.
> > >> > On Mon, Jul 4, 2011 at 6:25 AM, Giovanni Manghi
> > >> > wrote:
> > >> >> you need the SDKs from erdas and lizardtech
> > >> >> cheers
> > >> >> -- Giovanni --
> > >> >> On Mon, 2011-07-04 at 18:24 +0800, ahmad jauhari wrote:
> > >> >> > dear all,
> > >> >> > i have installed gdal-ecw-src and gdal-mrsid-src, but qgis
> > program can
> > >> >> > not access the file .ecw and file mrSID, anyone can help me.
> > thanks.
> > >> >> _______________________________________________
> > >> >> Qgis-user mailing list
> > >> >> Qgis-user at lists.osgeo.org
> > >> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
> > >> > all the best,
> > >> > Lee
all the best,
Lee
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110706/0d449a97/attachment.html>
