[Qgis-user] Bugs
jonathanmoules at warwickshire.gov.uk jonathanmoules at warwickshire.gov.uk
Thu Jul 7 07:38:03 PDT 2011
Hi Both,
        Yep, this does it. Thanks.
Jonathan
To:     <jonathanmoules at warwickshire.gov.uk>
Cc:     <qgis-user at lists.osgeo.org>
Date:   07/07/2011 15:36
Subject:        Re: [Qgis-user] Bugs
Jonathan,
> I haven't changed any of the plugins (or indeed, any settings
whatsoever),
they're all on default. I suspected it was for showing your own copyright,
but couldn't see it in the options page. Even now that I know where it is
(plugins), there's no obvious way to change the text, only enable/disable
it via "manage plugins". Not that this is important to me, it's just weird
having someone else's copyright on my map by default.
To change the copyright plugin settings, ensure the ?Plugins? toolbar is
shown, and this should show a copyright symbol. Click on that and the
settings will appear.
Regards,
Rob
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110707/a97b009f/attachment.html>
