[Qgis-user] file ecw and mrsid in ubuntu doesn't work
Lee muellerl at gmail.com
Thu Jul 7 09:34:25 PDT 2011
I've received the following message from Lizardtech:
What would be a more user friendly process for you?
This sounds like a distribution issue.  The latest release of the SDK
creates a shared object on linux (where it used to be statically linked into
your application).
-chris
I'm not involved with development, but I do understand some changes in the
newer version make it so our scripts don't work for incorporating it. What
should be suggested to ensure we can utilize the newer version?
On Wed, Jul 6, 2011 at 2:56 PM, Giovanni Manghi
<giovanni.manghi at gmail.com>wrote:
> On Wed, 2011-07-06 at 14:51 -0400, Lee wrote:
> > I've had trouble finding the correct SDK. The one I've downloaded is a
> > newer version and requires a different procedure. Where did you find
> > the 4.1 SDK?
> Common problem with this kinf of formats, they updated the SDK and the
> old version is no more available for download. Meanwhile the gdal
> "connector" has not been updated yet, and to tell the truth I don't
> if/when it will be.
> Cheers
> -- Giovanni --
all the best,
Lee
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110707/9cc18052/attachment.html>
