[Qgis-user] file ecw and mrsid in ubuntu doesn't work
Pirmin Kalberer pi_ml at sourcepole.com
Thu Jul 7 11:49:59 PDT 2011
Hi Lee,
Am Donnerstag, 7. Juli 2011, 18.34:25 schrieb Lee:
> I've received the following message from Lizardtech:
> What would be a more user friendly process for you?
Could you ask back for a permission to distribute GDAL (www.gdal.org) together
with a statically or dynamically linked SDK shared object library?
Regards
Pirmin
> This sounds like a distribution issue.  The latest release of the SDK
> creates a shared object on linux (where it used to be statically linked
> into your application).
> -chris
> I'm not involved with development, but I do understand some changes in the
> newer version make it so our scripts don't work for incorporating it. What
> should be suggested to ensure we can utilize the newer version?
> On Wed, Jul 6, 2011 at 2:56 PM, Giovanni Manghi
> <giovanni.manghi at gmail.com>wrote:
> > On Wed, 2011-07-06 at 14:51 -0400, Lee wrote:
> > > I've had trouble finding the correct SDK. The one I've downloaded is a
> > > newer version and requires a different procedure. Where did you find
> > > the 4.1 SDK?
> > Common problem with this kinf of formats, they updated the SDK and the
> > old version is no more available for download. Meanwhile the gdal
> > "connector" has not been updated yet, and to tell the truth I don't
> > if/when it will be.
> > Cheers
> > -- Giovanni --
Pirmin Kalberer
Sourcepole  -  Linux & Open Source Solutions
http://www.sourcepole.com
