[Qgis-user] Table/Attribute joins
Lee
muellerl at gmail.com
Mon Jul 11 17:37:47 PDT 2011
You are a genius. What a simple solution. I feel ashamed. Thank you very
much.
On Mon, Jul 11, 2011 at 8:16 PM, Ramon Andinach <custard at westnet.com.au>wrote:
> On 12/07/2011, at 03:26 , Lee wrote:
> > I've utilized the table join feature currently included in the 1.7
> release. I have a parcel ownership layer within a city environment. I have
> selected some of these parcels and added them to a new shapefile. I'm
> attempting to grab the data from the original parcel file and append it to
> the new shapefile so I still have ownership information. When I do a table
> join through properties, the information shows up in the attribute table...
> but not in the .dbf file, nor can I edit it in the table editor plugin.
> Therefore, I have no ability to edit how this information is displayed, or
> print it along with a key. It seems the join only exists in the memory of
> qgis, and it is never actually appended to the database file...
> > Any ideas?
> > all the best,
> > Lee
> Yep, the join is only in the memory. But if you save (using "save as" or
> "Save selection as"), the join should be preserved in the new file.
> So either you can join to your original layer, select the ones of interest
> and resave that new shape file, or
> Join to your new shape file and save as a new shape file.
> Hope that's of some use.
> -ramon._______________________________________________
> Qgis-user mailing list
all the best,
Lee
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110711/679c6fbd/attachment.html>
