[Qgis-user] Customized-QGis for Land Management
Andreas Neumann
a.neumann at carto.net
Tue Jul 12 23:28:17 PDT 2011
On Wed, 13 Jul 2011 10:25:39 +0700, Yudho Indardjo wrote:
> Dear QGIS suhu,
don't know what a "suhu" is ...
> Where can I find a shortest way to develop QGIS as a main software
> for
> Land Management?
> Im just considering :
> - design a customized-QGIS
This is already possible. You have a lot of options:
* change menu entries and toolbars
* customize settings and paths
* write plugins
* embed QGIS into your own application (not really recommended unless
really needed, but it works)
etc.
See also
http://www.qgis.org/images/usermeetings/rapperswil/slides/20110506_konfektionierung_von_qgis_cedric.pdf
- these slides are in german, but I guess you will easily understand
them as the options are in english anyway.
> - connection with GPS for realtime updating location
also possible --> see GPS Tools plugin
> - storing attribut data into a database system (ex. MS Access)
also possible, but I would not recommend MS Access. Access to MS Access
may even be read-only. It has a lot of limitations and can't be easily
transfered to other platforms or applications. I would recommend either
PostgreSQL/Postgis, for a central solution, or SpatiaLite for a mobile
solution. Both can be used together in the sense of a checkout from
Postgis to SpatiaLite, disconnected editing, and check-in of the
changes. See "Offline Editing" plugin.
Hope this helps,
Andreas
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
