[Qgis-user] Customized-QGis for Land Management
Yudho Indardjo
yudhoi at gmail.com
Wed Jul 13 00:39:41 PDT 2011
Thank you very much..
and "suhu" means *an expert*..
On Wed, Jul 13, 2011 at 1:28 PM, Andreas Neumann <a.neumann at carto.net>wrote:
> Hi,
> On Wed, 13 Jul 2011 10:25:39 +0700, Yudho Indardjo wrote:
>> Dear QGIS suhu,
> don't know what a "suhu" is ...
> Where can I find a shortest way to develop QGIS as a main software for
>> Land Management?
>> Im just considering :
>> - design a customized-QGIS
> This is already possible. You have a lot of options:
> * change menu entries and toolbars
> * customize settings and paths
> * write plugins
> * embed QGIS into your own application (not really recommended unless
> really needed, but it works)
> etc.
> See also http://www.qgis.org/images/**usermeetings/rapperswil/**
> slides/20110506_**konfektionierung_von_qgis_**cedric.pdf<http://www.qgis.org/images/usermeetings/rapperswil/slides/20110506_konfektionierung_von_qgis_cedric.pdf>- these slides are in german, but I guess you will easily understand them as
> the options are in english anyway.
> - connection with GPS for realtime updating location
> also possible --> see GPS Tools plugin
> - storing attribut data into a database system (ex. MS Access)
> also possible, but I would not recommend MS Access. Access to MS Access may
> even be read-only. It has a lot of limitations and can't be easily
> transfered to other platforms or applications. I would recommend either
> PostgreSQL/Postgis, for a central solution, or SpatiaLite for a mobile
> solution. Both can be used together in the sense of a checkout from Postgis
> to SpatiaLite, disconnected editing, and check-in of the changes. See
> "Offline Editing" plugin.
> Hope this helps,
> Andreas
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
Yudho Indardjo
+62 812 2728 663
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110713/7171aa13/attachment.html>
