[Qgis-user] Customized-QGis for Land Management
Noli Sicad
nsicad at gmail.com
Wed Jul 13 00:59:15 PDT 2011
Hi Yudho,
PyQGIS with Spatialite is good way to start your project. Forget about
Access. Use Spatialite.
http://translate.google.com/translate?js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&sl=auto&tl=en&u=http%3A%2F%2Fgeotux.tuxfamily.org%2Findex.php%3Foption%3Dcom_myblog%26task%3Dview%26id%3D251%26Itemid%3D59
http://osgeo-org.1803224.n2.nabble.com/PyQGIS-Selecting-Spatialite-Datasource-at-runtime-td5518560.html
Noli
On 7/13/11, Yudho Indardjo <yudhoi at gmail.com> wrote:
> Thank you very much..
> and "suhu" means *an expert*..
> On Wed, Jul 13, 2011 at 1:28 PM, Andreas Neumann <a.neumann at carto.net>wrote:
>> Hi,
>> On Wed, 13 Jul 2011 10:25:39 +0700, Yudho Indardjo wrote:
>>> Dear QGIS suhu,
>> don't know what a "suhu" is ...
>> Where can I find a shortest way to develop QGIS as a main software for
>>> Land Management?
>>> Im just considering :
>>> - design a customized-QGIS
>> This is already possible. You have a lot of options:
>> * change menu entries and toolbars
>> * customize settings and paths
>> * write plugins
>> * embed QGIS into your own application (not really recommended unless
>> really needed, but it works)
>> etc.
>> See also http://www.qgis.org/images/**usermeetings/rapperswil/**
>> slides/20110506_**konfektionierung_von_qgis_**cedric.pdf<http://www.qgis.org/images/usermeetings/rapperswil/slides/20110506_konfektionierung_von_qgis_cedric.pdf>-
>> these slides are in german, but I guess you will easily understand them as
>> the options are in english anyway.
>> - connection with GPS for realtime updating location
>> also possible --> see GPS Tools plugin
>> - storing attribut data into a database system (ex. MS Access)
>> also possible, but I would not recommend MS Access. Access to MS Access
>> may
>> even be read-only. It has a lot of limitations and can't be easily
>> transfered to other platforms or applications. I would recommend either
>> PostgreSQL/Postgis, for a central solution, or SpatiaLite for a mobile
>> solution. Both can be used together in the sense of a checkout from
>> Postgis
>> to SpatiaLite, disconnected editing, and check-in of the changes. See
>> "Offline Editing" plugin.
>> Hope this helps,
>> Andreas
>> Andreas Neumann
>> Böschacherstrasse 10A
>> 8624 Grüt (Gossau ZH)
>> Switzerland
>> ______________________________**_________________
>> Qgis-user mailing list
>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
> Yudho Indardjo
> +62 812 2728 663
