[Qgis-user] ECW Projection
jonathanmoules at warwickshire.gov.uk
Wed Jul 13 06:35:57 PDT 2011
Just wondering if the project was aware of this as part of their
ongoing ECW issues, but when you load a geo-referenced ECW into QGIS, it
doesn't actually get properly referenced. Even if you manually set the
projection for both the layer and the project it remains un-referenced
with QGIS giving 0,0 co-ords to the top-left of the image. This same ECW
works fine in GvSIG, Kosmo, MapWindow and ArcGIS. It's projected to EPSG:
27700.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110713/e727dce8/attachment.html>
