[Qgis-user] ECW Projection
jonathanmoules at warwickshire.gov.uk
Wed Jul 13 07:15:46 PDT 2011
I downloaded GDAL to test it, but of course it turns out you need a plugin
to read ECW's which requires at least three different other things to be
installed, so I'm afraid I'm not able to oblige that.
The original file is far too large to send, so I clipped it, but
unfortunately the clip works within QGIS, so I'm not sure how you'll test
it, but see attached for it anyway
To: qgis-user at lists.osgeo.org
Date: 13/07/2011 14:46
Subject: Re: [Qgis-user] ECW Projection
Sent by: qgis-user-bounces at lists.osgeo.org
Le 13/07/2011 15:35, jonathanmoules at warwickshire.gov.uk a écrit :
> Just wondering if the project was aware of this as part of their ongoing
> ECW issues, but when you load a geo-referenced ECW into QGIS, it doesn't
> actually get properly referenced. Even if you manually set the
> projection for both the layer and the project it remains un-referenced
> with QGIS giving 0,0 co-ords to the top-left of the image. This same ECW
> works fine in GvSIG, Kosmo, MapWindow and ArcGIS. It's projected to
> EPSG: 27700.
> Jonathan
What does gdalinfo report about this file ? Can you provide a small sample
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110713/61aebc61/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110713/61aebc61/attachment.obj>
