[Qgis-user] ECW Projection
Giovanni Manghi giovanni.manghi at gmail.com
Wed Jul 13 08:15:26 PDT 2011
>         Just wondering if the project was aware of this as part of
> their ongoing ECW issues, but when you load a geo-referenced ECW into
> QGIS, it doesn't actually get properly referenced. Even if you
> manually set the projection for both the layer and the project it
> remains un-referenced with QGIS giving 0,0 co-ords to the top-left of
> the image. This same ECW works fine in GvSIG, Kosmo, MapWindow and
> ArcGIS. It's projected to EPSG: 27700.
I was chatting a while ago with W. Macho and it was saying to me that it
had a similar problem, with all his ECWs rasters to render on top of
each other, as they don't had any referencing.
A few tests and we find the issue. It depends on the extension of the
file that (I guess) define the referencing. If the file is .aux then it
si fine for gdal, if it is .aux.xml (if I recall correctly) it seems
that gdal can't read the referencing.
cheers
-- Giovanni --
