[Qgis-user] ECW Projection
jonathanmoules at warwickshire.gov.uk
Wed Jul 13 08:31:26 PDT 2011
I can confirm my file has a .ecw.aux.xml
If I remove the ".xml" from the file name it does work in qgis.
Thanks
Jonathan
From: Giovanni Manghi <giovanni.manghi at gmail.com>
To: jonathanmoules at warwickshire.gov.uk
Cc: qgis-user at lists.osgeo.org
Date: 13/07/2011 16:15
Subject: Re: [Qgis-user] ECW Projection
> Just wondering if the project was aware of this as part of
> their ongoing ECW issues, but when you load a geo-referenced ECW into
> QGIS, it doesn't actually get properly referenced. Even if you
> manually set the projection for both the layer and the project it
> remains un-referenced with QGIS giving 0,0 co-ords to the top-left of
> the image. This same ECW works fine in GvSIG, Kosmo, MapWindow and
> ArcGIS. It's projected to EPSG: 27700.
I was chatting a while ago with W. Macho and it was saying to me that it
had a similar problem, with all his ECWs rasters to render on top of
each other, as they don't had any referencing.
A few tests and we find the issue. It depends on the extension of the
file that (I guess) define the referencing. If the file is .aux then it
si fine for gdal, if it is .aux.xml (if I recall correctly) it seems
that gdal can't read the referencing.
cheers
-- Giovanni --
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110713/12666d63/attachment.html>
