[Qgis-user] install qgis server on RHEL?
Volker Fröhlich
volker27 at gmx.at
Wed Jul 20 05:12:43 PDT 2011
You can also compile the current source code by creating a tarball and using
that with the spec file of the RPM.
This gives you the advantages of:
- Package management
- Distributions specific adaptions made for the package
- No need to think a lot
Volker
Am Mittwoch, 20. Juli 2011, 13:45:28 schrieb Andreas Neumann:
> Hi,
> Personally I would invest the time and compile from Source. It is
> probably worth, because there may/will often be fixes during releases
> that are worth a recompile and otherwise you would have to wait.
> Once setup you can just git pull and recompile. Very fast and easy.
> Andreas
> On Wed, 20 Jul 2011 10:40:24 +0200, Richard Duivenvoorde wrote:
> > Hi List,
> > I have a RHEL6 demo machine running.
> > I want to install/demo qgis-server on it.
> > What is the easiest way to install that?
> > Normal compile of qgis? (gdal/proj is already done there for
> > mapserver...), or are there easier packages available (like for
> > ubuntu).
> > Grtz
> > Richard
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
