[Qgis-user] QGIS -> MySQL -> Mapserver ??
Saber Razmjooei
razmjooeis at faunalia.co.uk
Wed Jul 27 01:34:37 PDT 2011
Chris
I presume your ogr can handle mysql if you can open it in QGIS. But to
confirm could you run:
ogrinfo --formats
from terminal and check if you have
-> "MSSQLSpatial" (read/write)
Is your database large? Have you considered using PostGIS?
Cheers
Saber
On 27/07/11 07:45, Chris Green wrote:
> Hi QGIS users
> I have a problem getting Mapserver to display vector line features which I
> created with QGIS and saved as spatial objects in MySQL...I asked for some
> advice on this from the Mapserver forum yesterday but had no responses,
> perhaps someone in this forum has some experience to offer?
> As explained in the question below, I can create line features in QGIS, save
> them in a MySQL table, and recall and display them with QGIS without any
> problem. But the same features do not appear to be recognised by OGRInfo or
> by Mapserver. The line features are saved as BLOB data in a MySQL MyISAM
> table in a column which is defined as type 'geometry'. MySQL can create a
> spatial index of these features.
> The table is accessed by QGIS as a database layer via the 'Add Vector Layer'
> dialogue. I am using QGIS 1.7.
> It's not really a QGIS problem, but I spent all day wrestling with this
> yesterday but have not solved it. Any suggestions?
> Chris
> I'm having some trouble with an OGR connection to a MySQL database. The data
> I'm trying to access was created using QGIS as a line layer and saved in a
> MySQL table as a BLOB in a geometry column. I can access and properly
> display this line data using QGIS, but not so far via Mapserver - nothing is
> drawn and I can't see any error.
> I am using Mapserver 6.0 and my mapfile is very similar to the example in
> theMapserver / MYSQL documentation:
> LAYER
> NAME "testLine"
> TYPE LINE
> STATUS DEFAULT
> CONNECTIONTYPE OGR
> CONNECTION "mysql:testDB,user=admin,password=password,port=3306"
> DATA "SELECT Geometry from testLine"
> CLASS
> STYLE
> COLOR 0 0 0
> WIDTH 2
> END # style
> END # class
> END # layer
> If I look at the MySQL table using OGRinfo I see the following:
> Layer name: testLine
> Geometry: Unknown (any)
> Feature Count: 0
> Layer SRS WKT:
> (unknown)
> FID Coumn = id
> Geometry Column = Geometry
> The issue seems to be that OGRInfo and therefore MapServer does not
> recognise any features in the table, but QGIS using access to the same table
> finds and displays the features.
> Anyone have any ideas what I am doing wrong?
> Chris
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110727/c2ba3d45/attachment.html>
