[Qgis-user] QGIS -> MySQL -> Mapserver ??
Chris Green chris.green at ibstv.co.uk
Wed Jul 27 02:00:27 PDT 2011
Hi Saber
Thanks for the suggestion. When I run ogrinfo -formats I see that MySQL is
included, so that is not the problem.
It seems that the issue is about the way that I created and store the line
data, because I have tried with some point data and I don't have this
problem - I can create, save, and display points with QGIS and then both OGR
and MapServer are OK. But with line data it is different.
I can only assume that QGIS is sending the line data to MySQL in a format
that QGIS recognises when the data is retrieved, but which is not recognised
by OGR / MapServer.
Going to PostGIS would have to be a last resort, I have a lot of effort
invested in MySQL ..
Chris
From: Saber Razmjooei [mailto:razmjooeis at faunalia.co.uk]
Sent: 27 July 2011 09:35
To: Chris Green
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] QGIS -> MySQL -> Mapserver ??
Chris
I presume your ogr can handle mysql if you can open it in QGIS. But to
confirm could you run:
ogrinfo --formats
from terminal and check if you have
-> "MSSQLSpatial" (read/write)
Is your database large? Have you considered using PostGIS?
Cheers
Saber
On 27/07/11 07:45, Chris Green wrote:
Hi QGIS users
I have a problem getting Mapserver to display vector line features which I
created with QGIS and saved as spatial objects in MySQL...I asked for some
advice on this from the Mapserver forum yesterday but had no responses,
perhaps someone in this forum has some experience to offer?
As explained in the question below, I can create line features in QGIS, save
them in a MySQL table, and recall and display them with QGIS without any
problem.  But the same features do not appear to be recognised by OGRInfo or
by Mapserver. The line features are saved as BLOB data in a MySQL  MyISAM
table in a column which is defined as type 'geometry'. MySQL can create a
spatial index of these features.
The table is accessed by QGIS as a database layer via the 'Add Vector Layer'
dialogue. I am using QGIS 1.7.
It's not really a QGIS problem, but I spent all day wrestling with this
yesterday but have not solved it.  Any suggestions?
Chris
I'm having some trouble with an OGR connection to a MySQL database. The data
I'm trying to access was created using QGIS as a line layer and saved in a
MySQL table as a BLOB in a geometry column. I can access and properly
display this line data using QGIS, but not so far via Mapserver - nothing is
drawn and I can't see any error.
I am using Mapserver 6.0 and my mapfile is very similar to the example in
theMapserver / MYSQL  documentation:
LAYER
       NAME "testLine"
       TYPE   LINE
       STATUS  DEFAULT
       CONNECTIONTYPE  OGR
       CONNECTION  "mysql:testDB,user=admin,password=password,port=3306"
       DATA "SELECT Geometry from testLine"
       CLASS
              STYLE
                     COLOR  0 0 0
                     WIDTH  2
              END # style
       END # class
END # layer
If I look at the MySQL table using OGRinfo I see the following:
Layer name: testLine
Geometry: Unknown (any)
Feature Count: 0
Layer SRS WKT:
(unknown)
FID Coumn = id
Geometry Column = Geometry
The issue seems to be that OGRInfo and therefore MapServer does not
recognise any features in the table, but QGIS using access to the same table
finds and displays the features.
Anyone have any ideas what I am doing wrong?
Chris
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110727/414a5aee/attachment.html>
