[Qgis-user] KML to GoogleEarth
Giovanni Manghi
giovanni.manghi at gmail.com
Wed Jul 27 06:07:00 PDT 2011
Tha probably your shapefile is missing the .prj file, so when you load
it into QGIS it will probably be given the wrong CRS. Change it manually
then try again "save as..." and export in WGS84.
cheers
-- Giovanni --
On Wed, 2011-07-27 at 13:13 +0100, Walter Ludwick wrote:
> Hey, Saber: Thanks for the quick reply and explicit instructions.
> It was easy to do, i gave it a try -but still the same condition results, alas (i.e. the KML saved, even using that WGS84 as CRS, is interpreted by Google Earth as a set of polygons that covers the entire globe).
> I'm going to keep flailing, trying whatever other CRS seems likely, but if there be any further ideas of things i might try, please don't hesitate to suggest!
> /w
> On Jul 27, 2011, at 12:29 PM, Saber Razmjooei wrote:
> > The CRS you need is EPSG:4326
> > To find it easily, in search section change Authority to EPSG and search
> > for ID.
> > Type 4326 and highlight the line from Coordinate Reference System:
> > WGS84 EPSG:4326 3452
> > Click OK.
> >> As a complete n00b to this list -also very new to QGIS and GIS in general-
> >> i am having a problem that is i hope trivial to solve, for one of you with
> >> more experience!
> >> Essentially: to take a (vector) layer from QGIS and "save as..." KML, if i
> >> pass that dialog with defaults selected, i get a .KML file that doesn't
> >> make much sense to Google Earth -that is to say, Google Earth can read and
> >> will display the polygons, perhaps even in the right shape, tho i cannot
> >> be sure about that, because they display as lines that pretty much cover
> >> the entire globe!
> >> The one thing i can see that i think might be related to this problem is,
> >> the CRS (Co-ordinate Reference System) parameter, which appears in the
> >> "Save as..." dialog box with "Original CRS" as the default parameter...
> >> but then when i push the "browse" button, i am faced with an immense
> >> number of possibilities from which to choose, about which i have no idea.
> >> Can anyone shed some light, and perhaps suggest a CRS that just might
> >> work? The geography i am trying to describe is in coastal Portugal, if
> >> that makes any difference... /w
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
