[Qgis-user] Deleting a column from attribute table
adamu eloji
aeloji60 at yahoo.com
Wed Jul 27 08:19:23 PDT 2011
Dear All,
As a novice in QGIS, i created a column on an attribute which i dont want any more, pls can any experience person tell me how to delete the column.
Thanks
El-Oji
--- On Wed, 7/27/11, qgis-user-request at lists.osgeo.org <qgis-user-request at lists.osgeo.org> wrote:
From: qgis-user-request at lists.osgeo.org <qgis-user-request at lists.osgeo.org>
Subject: Qgis-user Digest, Vol 65, Issue 61
To: qgis-user at lists.osgeo.org
Date: Wednesday, July 27, 2011, 11:14 AM
Send Qgis-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Qgis-user digest..."
Today's Topics:
1. Re: object labels (Andreas Neumann)
2. RE: QGIS -> MySQL -> Mapserver ?? (Chris Green)
3. RE: QGIS -> MySQL -> Mapserver ?? (Saber)
4. DTclassifier is released (Maxim Dubinin)
Message: 1
Date: Wed, 27 Jul 2011 11:00:01 +0200
Subject: Re: [Qgis-user] object labels
To: <qgis-user at lists.osgeo.org>
Message-ID: <2634cc5e1e8f0d3a1c3ecba07210ba79 at carto.net>
Content-Type: text/plain; charset=UTF-8; format=flowed
Currently, you have to create a new column. I usually create a view in
Postgis for this purpose.
It is in on the wishlist that one can create a "virtual" column - not
only for labeling, but also for map tips and perhaps symbolization.
Until then you have to do it yourself.
Andreas
On Tue, 26 Jul 2011 22:51:34 +0200, Torsten Lange wrote:
> Hi,
> Is there a way just to print - lets say - the first four letters of a
> objects
> name? Or must I create a new row for that?
> Thank you, Torsten
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
Message: 2
Date: Wed, 27 Jul 2011 10:00:27 +0100
Subject: RE: [Qgis-user] QGIS -> MySQL -> Mapserver ??
To: "'Saber Razmjooei'" <razmjooeis at faunalia.co.uk>
Cc: qgis-user at lists.osgeo.org
Message-ID: <02a401cc4c3b$a25fa3a0$e71eeae0$@green at ibstv.co.uk>
Content-Type: text/plain; charset="us-ascii"
Hi Saber
Thanks for the suggestion. When I run ogrinfo -formats I see that MySQL is
included, so that is not the problem.
It seems that the issue is about the way that I created and store the line
data, because I have tried with some point data and I don't have this
problem - I can create, save, and display points with QGIS and then both OGR
and MapServer are OK. But with line data it is different.
I can only assume that QGIS is sending the line data to MySQL in a format
that QGIS recognises when the data is retrieved, but which is not recognised
by OGR / MapServer.
Going to PostGIS would have to be a last resort, I have a lot of effort
invested in MySQL ..
Chris
From: Saber Razmjooei [mailto:razmjooeis at faunalia.co.uk]
Sent: 27 July 2011 09:35
To: Chris Green
Subject: Re: [Qgis-user] QGIS -> MySQL -> Mapserver ??
Chris
I presume your ogr can handle mysql if you can open it in QGIS. But to
confirm could you run:
ogrinfo --formats
from terminal and check if you have
-> "MSSQLSpatial" (read/write)
Is your database large? Have you considered using PostGIS?
Cheers
Saber
On 27/07/11 07:45, Chris Green wrote:
Hi QGIS users
I have a problem getting Mapserver to display vector line features which I
created with QGIS and saved as spatial objects in MySQL...I asked for some
advice on this from the Mapserver forum yesterday but had no responses,
perhaps someone in this forum has some experience to offer?
As explained in the question below, I can create line features in QGIS, save
them in a MySQL table, and recall and display them with QGIS without any
problem. But the same features do not appear to be recognised by OGRInfo or
by Mapserver. The line features are saved as BLOB data in a MySQL MyISAM
table in a column which is defined as type 'geometry'. MySQL can create a
spatial index of these features.
The table is accessed by QGIS as a database layer via the 'Add Vector Layer'
dialogue. I am using QGIS 1.7.
It's not really a QGIS problem, but I spent all day wrestling with this
yesterday but have not solved it. Any suggestions?
Chris
I'm having some trouble with an OGR connection to a MySQL database. The data
I'm trying to access was created using QGIS as a line layer and saved in a
MySQL table as a BLOB in a geometry column. I can access and properly
display this line data using QGIS, but not so far via Mapserver - nothing is
drawn and I can't see any error.
I am using Mapserver 6.0 and my mapfile is very similar to the example in
theMapserver / MYSQL documentation:
LAYER
NAME "testLine"
TYPE LINE
STATUS DEFAULT
CONNECTIONTYPE OGR
CONNECTION "mysql:testDB,user=admin,password=password,port=3306"
DATA "SELECT Geometry from testLine"
CLASS
STYLE
COLOR 0 0 0
WIDTH 2
END # style
END # class
END # layer
If I look at the MySQL table using OGRinfo I see the following:
Layer name: testLine
Geometry: Unknown (any)
Feature Count: 0
Layer SRS WKT:
(unknown)
FID Coumn = id
Geometry Column = Geometry
The issue seems to be that OGRInfo and therefore MapServer does not
recognise any features in the table, but QGIS using access to the same table
finds and displays the features.
Anyone have any ideas what I am doing wrong?
Chris
URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110727/414a5aee/attachment-0001.html
Message: 3
Date: Wed, 27 Jul 2011 10:55:20 +0100
To: Chris Green <chris.green at ibstv.co.uk>
Message-ID: <05cdp715sy1xrat8ywciguee.1311760349356 at email.android.com>
Content-Type: text/plain; charset=utf-8
As a test, worth converting the mysql vector to shapefile to see if the vector is shown properly.
Also checking webserver logs report for mapsever requests of the MySQL vector might help.
Chris Green <chris.green at ibstv.co.uk> wrote:
>Hi Saber
>by OGR / MapServer.
>Chris
>To: Chris Green
>Chris
>ogrinfo --formats
>Cheers
>Saber
>Hi QGIS users
>Chris
>LAYER
> NAME "testLine"
> TYPE LINE
> STATUS DEFAULT
> CONNECTIONTYPE OGR
> CLASS
> STYLE
> COLOR 0 0 0
> WIDTH 2
> END # style
> END # class
>END # layer
>Feature Count: 0
>Layer SRS WKT:
>(unknown)
>FID Coumn = id
>Chris
>_______________________________________________
Message: 4
Date: Wed, 27 Jul 2011 14:09:39 +0400
Subject: [Qgis-user] DTclassifier is released
To: qgis-developer at lists.osgeo.org
Message-ID: <77239752.20110727140939 at gis-lab.info>
Content-Type: text/plain; charset=us-ascii
Hi all,
To follow up on our demonstration in Lisbon.
We are happy to release our new plugin for streamlined remote sensing
data classification in QGIS [0]. Initially the plugin was
developed to provide easy to use tool to monitor forest cover
change, but it can be used to classify any type of targets.
Main features:
- all-in-one, with this plugin only QGIS is needed for all steps of
classification;
- decision trees, the plugin is using computer vision library OpenCV to
implement modern classification algorithm typically not available in
other software packages (both OS and proprietory);
- performance, another nice feature of OpenCV is that it is
very fast;
- multiple input rasters and multiple training layers;
Description, examples and sample data:
EN: http://gis-lab.info/qa/dtclassifier-eng.html
RU: http://gis-lab.info/qa/dtclassifier.html
Right now the windows binaries and source code are available.
Maxim
[0] http://www.nextgis.ru/projects/dtclassifier
End of Qgis-user Digest, Vol 65, Issue 61
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110727/2d5a5976/attachment.html>
